Hi I’m Paul and this is my very first post. Hello All and thank you in advance for your help.
I’ve just installed “NETMF and Gadgeteer Package 2014 R2 Beta-3” and setting up my first test project and have run into a problem.
On my board I got LED Strip 1.2 (Y) connected to port 5 which accepts C,S,Y but on the designer port 5 only shows C,S,X and wont allow me to connect it.
Port 5 & 6 show X instead of Y on the designer. Is this a bug?
So a X and S socket should be able to be a Y socket as well, since the pins will overlap (SPI CK/MOSI/MISO) but they do meet the expected possible pin availability requirement… You can’t however use the Y feature on say 6 without impacting socket 5 because these pins are exposed on both sockets…
@ Brett - This is what we thought at first but then SPI pins are shared among different sockets and you most certainly run into problems if you make them Y. Use X and it will make life easier for everyone.
IF you only have one S socket then you can keep it as Y.
Gus says the designer is correct, so the best place to use as a reference is the source code for the mainboard driver.
In the FEZCerberus_43.cs file the sockets are defined as follows
Socket 5 : P, C, S, X
Socket 6 : P, U, S, X
So yes, both socket 5 and 6 can be used for PWM.
I would provide a link to the mainboard code, but I have not been keeping up to date with the new public location so I still reference the codeplex repository, I think this has all moved so I do not want to point you to something that is possibly not going to be maintained.
As @ Brett pointed out, Y can be X, but X cannot be Y. Due to the pin conflicts between socket 5 and 6, these sockets are and should be limited to X.
You can use them as Y, individually, but you can’t use one as S and one as Y because you’re conflicting with the SPI pins. You can use them both as X fine without conflict, you can use one as S and the other as X again without conflicts. If you really REALLY wanted to use one as a Y then you could modify the mainboard definitions so you didn’t get a pin conflicts but as everyone has pointed out, it’s safest to leave it as-is.
