I’ve tried to use Socket 4 Pin5 analog out to light a LED.
_analogOut = extender.SetupAnalogOutput(GT.Socket.Pin.Five);
Return me the error:
“Socket 4 has an error with its Analog Output functionality. Please try a different socket.”
I downloaded Gadgeteer source code and debugging I’ve found the following:
#region Socket 4
// O
socket.AnalogOutput = new FEZCerberus_AnalogOut((Cpu.Pin)0);
I’ve changed it according Cerberus pin docs in:
socket.AnalogOutput = new FEZCerberus_AnalogOut(GHI.OSHW.Hardware.FEZCerberus.Pin.PA5);
and error has gone… but nothing happened!
Continuing debugging I found:
public void SetVoltage(double voltage)
Active = true;
// Check that voltage does not fall outside of mix/max range
if (voltage < _minVoltage)
throw new ArgumentOutOfRangeException("The minimum voltage of the analog output interface is 0.0V");
if (voltage > _maxVoltage)
throw new ArgumentOutOfRangeException("The maximum voltage of the analog output interface is 3.3V");
// Use the mainboard-specific analog
// aout.Set(voltageInUnits);
Method is not implemented yet?!?!
