Hello.
I’m trying to build the FEZ Cerberus firmware for Discovery4.
But everytime I get a compilation error…
My setup:
NETMF PK 4.2 QFE2
GHI sources from http://ghiopensource.codeplex.com/
Keil MDK Standard 4.54
VS 2010 SP1
Win 8 Pro x64
Compile commands:
setenv_mdk.cmd 4.54 c:\keil\arm
msbuild /p:flavor=release;memory=FLASH Solutions\FEZCerberus\dotNetMF.proj
The error is in MicroFrameworkPK_v4_2\DeviceCode\GHI\Configuration\dotNetMF.proj and MicroFrameworkPK_v4_2\DeviceCode\GHI\l
ibraries\GHI.OSHW.Hardware\Native\dotNetMF.proj
"d:\MicroFrameworkPK_v4_2\Solutions\FEZCerberus\dotNetMF.proj" (domyślny element docelowy) (1)->
"d:\MicroFrameworkPK_v4_2\Solutions\FEZCerberus\TinyCLR\TinyCLR.proj" (element docelowy Build) (123) ->
"d:\MicroFrameworkPK_v4_2\DeviceCode\GHI\libraries\GHI.OSHW.Hardware\Native\dotNetMF.proj" (element docelowy Build) (137) ->
(element docelowy ArmCompileCPP) ->
d:\MicroFrameworkPK_v4_2\tools\targets\Microsoft.SPOT.System.MDK.targets(262,4): error MSB3073: The command ""c:\keil\arm\bin40\armcc.exe" --cpp
--diag_suppress 2874,111,161,550,C3011 --diag_suppress 66,161,230,1293 --split_sections -DMDK_V3_1 -DARM_V3_1 -Id:\MicroFrameworkPK_v4_2\DeviceCode
-Id:\MicroFrameworkPK_v4_2\DeviceCode\pal\rtip -Id:\MicroFrameworkPK_v4_2\DeviceCode\pal\rtip\rtpcore -Id:\MicroFrameworkPK_v4_2\devicecode\pal\rtip\
tinyclr --feedback d:\MicroFrameworkPK_v4_2\tools\make\Feedback\FEZCerberus_MDK4.54.feedback -DTINYCLR_ENABLE_SOURCELEVELDEBUGGING -DCOMPILE_THUMB2
-DVERSION_MAJOR=4 -DVERSION_MINOR=2 -DVERSION_BUILD=0 -DVERSION_REVISION=0 -DOEMSYSTEMINFOSTRING="\"Copyright GHI Electronics, LLC\"" -DPLATFORM_ARM
_FEZCerberus -DTARGETLOCATION_FLASH -DLITTLE_ENDIAN -DPLATFORM_NO_CLR_TRACE=1 -DTINYCLR_NO_IL_INLINE=1 --thumb --apcs=interwork --cpu Cortex-M
4.fp --littleend --no_debug --dwarf2 --no_debug_macros -O2 --inline -Otime --no_autoinline -DNDEBUG -Ic:\keil\arm\RV31\INC -Id:\MicroFrameworkPK_
v4_2\DeviceCode\Targets\Native\Interop\GHI_OSHW_Hardware -Id:\MicroFrameworkPK_v4_2\DeviceCode\include -Id:\MicroFrameworkPK_v4_2\DeviceCode\Cores\ar
m -Id:\MicroFrameworkPK_v4_2\Support\Include -Id:\MicroFrameworkPK_v4_2\crypto\inc -Id:\MicroFrameworkPK_v4_2\CLR\Include -Id:\MicroFrameworkPK_v4
_2\CLR\Libraries\CorLib -Id:\MicroFrameworkPK_v4_2\CLR\Libraries\SPOT -Id:\MicroFrameworkPK_v4_2\CLR\Libraries\SPOT_Hardware -Id:\MicroFrameworkPK_v4
_2\CLR\Libraries\SPOT_Graphics -Id:\MicroFrameworkPK_v4_2\CLR\Libraries\SPOT_Net -Id:\MicroFrameworkPK_v4_2\CLR\Libraries\SPOT_Net_Security -Id:\Micr
oFrameworkPK_v4_2\Solutions\FEZCerberus -Id:\MicroFrameworkPK_v4_2\devicecode\Targets\Native\STM32F4 -Id:\MicroFrameworkPK_v4_2\DeviceCode\Cores\arm
-Id:\MicroFrameworkPK_v4_2\DeviceCode\Cores\arm\Include -Id:\MicroFrameworkPK_v4_2\DeviceCode -Id:\MicroFrameworkPK_v4_2\DeviceCode\Include -Id:\Micr
oFrameworkPK_v4_2\DeviceCode\Targets\Native\STM32F4\FEZCerberus -Id:\MicroFrameworkPK_v4_2\Support\Include -Id:\MicroFrameworkPK_v4_2\DeviceCode\incl
ude -Id:\MicroFrameworkPK_v4_2\CLR\include -Id:\MicroFrameworkPK_v4_2\Crypto\inc -o d:\MicroFrameworkPK_v4_2\BuildOutput\THUMB2\MDK4.54\le\FLASH\r
elease\FEZCerberus\obj\DeviceCode\Targets\Native\Interop\GHI_OSHW_Hardware\HAL_GHI_OSHW_Hardware_LCDController.obj -c d:\MicroFrameworkPK_v4_2\Device
Code\GHI\libraries\GHI.OSHW.Hardware\Native\HAL_GHI_OSHW_Hardware_LCDController.cpp " exited with code 1. [d:\MicroFrameworkPK_v4_2\DeviceCode\GHI\l
ibraries\GHI.OSHW.Hardware\Native\dotNetMF.proj]
"d:\MicroFrameworkPK_v4_2\DeviceCode\GHI\Configuration\dotNetMF.proj" (element docelowy Build) (142) ->
v4_2\DeviceCode\GHI\Configuration -Id:\MicroFrameworkPK_v4_2\DeviceCode\include -Id:\MicroFrameworkPK_v4_2\DeviceCode\Cores\arm -Id:\MicroFrameworkPK
_v4_2\Support\Include -Id:\MicroFrameworkPK_v4_2\crypto\inc -Id:\MicroFrameworkPK_v4_2\CLR\Include -Id:\MicroFrameworkPK_v4_2\CLR\Libraries\CorLib
-Id:\MicroFrameworkPK_v4_2\CLR\Libraries\SPOT -Id:\MicroFrameworkPK_v4_2\CLR\Libraries\SPOT_Hardware -Id:\MicroFrameworkPK_v4_2\CLR\Libraries\SPOT_G
raphics -Id:\MicroFrameworkPK_v4_2\CLR\Libraries\SPOT_Net -Id:\MicroFrameworkPK_v4_2\CLR\Libraries\SPOT_Net_Security -Id:\MicroFrameworkPK_v4_2\Solut
ions\FEZCerberus -Id:\MicroFrameworkPK_v4_2\devicecode\Targets\Native\STM32F4 -Id:\MicroFrameworkPK_v4_2\DeviceCode\Cores\arm -Id:\MicroFrameworkPK_v
4_2\DeviceCode\Cores\arm\Include -Id:\MicroFrameworkPK_v4_2\DeviceCode -Id:\MicroFrameworkPK_v4_2\DeviceCode\Include -Id:\MicroFrameworkPK_v4_2\Devic
eCode\Targets\Native\STM32F4\FEZCerberus -Id:\MicroFrameworkPK_v4_2\Support\Include -Id:\MicroFrameworkPK_v4_2\DeviceCode\include -Id:\MicroFramework
PK_v4_2\CLR\include -Id:\MicroFrameworkPK_v4_2\Crypto\inc -o d:\MicroFrameworkPK_v4_2\BuildOutput\THUMB2\MDK4.54\le\FLASH\release\FEZCerberus\obj\
DeviceCode\GHI\Configuration\OSHW_Configuration.obj -c d:\MicroFrameworkPK_v4_2\DeviceCode\GHI\Configuration\OSHW_Configuration.cpp " exited with co
de 1. [d:\MicroFrameworkPK_v4_2\DeviceCode\GHI\Configuration\dotNetMF.proj]
