Using all the latest I have noticed that the Fez Cerberus is unreliable using DHCP.
It looks to me like the DHCP protocol handling is the problem, is this common code with say the spider?
It sometimes works but mostly it is unreliable. Has anyone else had this problem, I have noticed several threads on this topic, but I am unsure what the current status is, It is not mentioned in the Issues.
thanks for replies, it looks like dhcp is still an issue with Cerberus then. ;-(
just tried the spider and it seems ok,
on the Cerberus (Ethernet firmware) my suspicions lie with the router perhaps being correctly ‘over’ pedantic about the protocol, without deep analysis I see a discover and an offer then a nak.
fwiw I tried mIP on Cerberus and it worked, but it would be a lot easier to use the built in Ethernet.
Gus what should we do,I much prefer the Cerberus to the spider.
@ Peter Kenyon - we are limited on how much time we put in open source unfortunately. The sources are open for anyone to improve and an issue report can be place to Microsoft on codeplex.
I’ve got my Cerberus boards happily using DHCP with Netgear and DLink (running DD-WRT) routers, so I think some packet sniffing will be required to figure out the problem you are having as certainly its not universal.
Ive had a quick look, and managed to capture a successful dhcp and the much more common failure and it seems that the dhcp state machine is all over the place, even the good one sends multiple requests, the bad case it gets an offer then starts to send a discover, etc etc.
