Hello,
Is there a way to change the debug mode on cerberus (like a serial port)? I’m trying to use the usb client.
I’ve searched the entire forum but couldn’t find an answer.
Hello,
I dont know if I understand exactly what you mean but perhaps a solution could be to use a Serial-USB Module https://www.ghielectronics.com/catalog/product/287
You need to recompile the firmware with serial debugging. Only premium devices have a dynamic switch.
I downloaded all the necessary things to recompile the Cerberus firmware.
Could you please guide me to the config file where the switch/directive is?
I actually found the config file yesterday and managed to change the debug port (to COM3), recompiled and now the usb client works.
I will also try using the 4.3 firmware.
Thank you all for the answers.
Hi godFather89
I’ve got the same problem.
but did not solve the problem.
If you can help me with this I would be very happy.
I have FEZ Cerberus Mainboard
How to tell if you have done here, and you have helped me a lot to like me who have this problem.
ARMA this thread is really old so if you have an issue you should start your own discussion thread, you’ll get lots of help from us all
