How I can connect the SD Card module using SPI to FEZ Cerb40? Are there any libraries which can help me working with SD Card?
regards,
Sylvester
regards,
Sylvester
Cerb40 supports SD just like the full Cerberus. Simply wire up according to the pins on Cerberus’ F socket. The Pin Detect isn’t broken out but you can use any other pin you like.
Sylvester, remember that netmf doesn’t use SPI like Arduinos do for SD card access
