I have a project that requires a web page front end to control and display data from the system. I would like to have more than just text on the web page. I want it to have dials and sliders and nice on/off buttons, etc. Has to be a totally embedded solution so I can just put in the FEZ IP and the web page will be served up. I’m new to providing a web page front end and not really sure where/how to proceed yet. Would the code be the same if I were to have a panda or domino with an ethernet shield attached comapred to using the built in ethernet of the cobra?
Which FEZ is the easiest for a noob to meet my needs?
FEZ Panda with Ethernet shield is all you need. If you want to fetch images from SD card for your web page then you need SD expansion but I recommend FEZ Domino since you get both, SD and USB host.
