G120 - MF 4.2.8
Although hard to proof for me, I have some sense that the current related WiFi - DHCP - Socket problems on the G120 has to do with internal storage / memory management of variables in non volatile memory / flash.
I mentioned the example below in another topic, but for now added simple WiFi open - Close. Run this example using the debugger, restart the debug sessions 2 or 3 times and WiFi will try to update the firmware… Also notice that data in EWR is lost the 3rd run…
Found debugger!
Create TS.
Loading start at a0e00000, end a0e0fc38
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: G120EWR (1.0.0.0) Attaching deployed file.
Assembly: GHI.Premium.Net (4.2.8.0) Attaching deployed file.
Assembly: GHI.Premium.System (4.2.8.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0) Attaching deployed file.
Assembly: GHI.Premium.Hardware.G120 (4.2.8.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.2.0.0) Resolving.
GC: 1msec 304392 bytes used, 7035276 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 7035276 bytes
Type 17 (ASSEMBLY ): 11544 bytes
Type 1E (BINARY_BLOB_HEAD ): 292752 bytes
GC: performing heap compaction…
Ready.
New configuration, defaults saved
EWR test start
#### Exception GHI.Premium.Net.NetworkInterfaceExtensionException - 0x00000000 (1) ####
#### Message:
#### GHI.Premium.Net.WiFiRS9110::RunFirmware [IP: 0049] ####
#### GHI.Premium.Net.WiFiRS9110::Open [IP: 0014] ####
Start Updating WiFi module firmware:
This might take up to 1 minute
0 Sec
1 Sec
2 Sec
3 Sec
4 Sec
5 Sec
6 Sec
7 Sec
8 Sec
9 Sec
10 Sec
using GHI.Premium.Hardware;
using GHI.Premium.Net;
using GHI.Premium.System;
namespace G120EWR
private static readonly Configuration Config = new Configuration();
private static WiFiRS9110 _wifi;
Debug.Print("EWR test start");
_wifi = new WiFiRS9110(SPI.SPI_module.SPI3, G120.Pin.P1_10, G120.Pin.P0_5, G120.Pin.P1_8);
try
if (!_wifi.IsOpen)
_wifi.Open();
catch (Exception e)
Debug.Print("WiFi Open Exception: " + e.Message);
_wifi.Close();
// Place a breakpoint here and restart a debug session.
public sealed class Configuration
private static ExtendedWeakReference _settingsReference;
internal AppSettings Settings = new AppSettings();
public Configuration()
_settingsReference = ExtendedWeakReference.RecoverOrCreate(typeof (AppSettings), 0,
ExtendedWeakReference.c_SurviveBoot |
ExtendedWeakReference.c_SurvivePowerdown);
_settingsReference.Priority = (int) ExtendedWeakReference.PriorityLevel.System;
Settings = _settingsReference.Target as AppSettings;
if (Settings == null)
// Must be a first time init
_settingsReference.Target = Settings;
Util.FlushExtendedWeakReferences();
Debug.Print("New configuration, defaults saved");
// !!! EWR destroyed when next method "PushBackIntoRecoverList" is called !!!
_settingsReference.PushBackIntoRecoverList();
Debug.Print("Configuration loaded");
public void Save()
[Serializable]
internal sealed class AppSettings
public string SomeConfigData = "just some text";
