Is the FEZ Hydra Mainboard @ 200mHz the fastest board that GHI sells? I am new to .NET micro and would like to control the TE35 touch screen with the fastest GHI CPU board because I’m concerned about screen redraw speed. I basically want to show some analog gauges on the screen along with some buttons presses represented by icons. 256 bit color is good enough. Could this setup do a 30 Hz screen refresh @ 320 x 240? Also, would I use GDI in .NET micro to code the gauges and icon presses? Where would the bitmaps be stored - ie: is SD card fast enough for reading images with a 30 Hz referesh? In actuality, I would really only need to change the dial positions in the gauges and the button pressed/unpressed look so writing to only the changed portions of the screen might be good enough.
Thanks!
Danh
