Would it be possible to change the RLP.LoadELF() method, so it can load elf files with .text and static data regions into FLASH instead of RAM? I have figured out that, when doing graphics stuff in RLP, that change would give a 2x to 3x speed boost.
I’m trying to figure out how I can load my own procedures to FLASH and then jump to the address, but that would be a dirty work-around. And I would have to make an assumption of which flash area is free to use.
I guess it would be easier for GHI to implement this in the RLP extension.
F.e. it would then be possible to use a linkscript like this:
OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm")
OUTPUT_ARCH(arm)
MEMORY
FLASH (wx) : ORIGIN = 0x803BE000, LENGTH = 0x00040000
SDRAM (wx) : ORIGIN = 0xA0F00000, LENGTH = 0x000FFFFC
SECTIONS
. = ALIGN(4);
.text :
*(.text)
} > FLASH
. = ALIGN(4);
.rodata :
*(.rodata )
} > FLASH
. = ALIGN(4);
.data :
*(.data)
} > FLASH
. = ALIGN(4);
.bss :
__bss_start__ = .;
*(.bss)
__bss_end__ = .;
} > SDRAM
end = .; /* define a global symbol marking the end of application RAM */
