I just tried to load an existing XML file to the Glide editor and a couple of the elements where reset to defaults.
This is the xml I was trying to load.
<Glide Version="1.0.6">
<Window Name="densityWindow" Width="480" Height="272" BackColor="F0F0A0">
<Button Name="cancelButton" X="392" Y="222" Width="80" Height="42" Alpha="255" Text="Cancel" Font="4" FontColor="000000" DisabledFontColor="808080" TintColor="000000" TintAmount="0"/>
<Button Name="acceptButton" X="8" Y="222" Width="80" Height="42" Alpha="255" Text="Accept" Font="4" FontColor="000000" DisabledFontColor="808080" TintColor="000000" TintAmount="0"/>
<TextBlock Name="instance96290" X="220" Y="30" Width="100" Height="32" Alpha="255" Text="Density (15C)" TextAlign="Left" TextVerticalAlign="Middle" Font="4" FontColor="0" BackColor="000000" ShowBackColor="False"/>
<TextBox Name="densityText" X="320" Y="30" Width="80" Height="32" Alpha="255" Text="0.0" TextAlign="Right" Font="4" FontColor="000000"/>
<TextBlock Name="instance102286" X="0" Y="0" Width="480" Height="24" Alpha="255" Text="Fuel Density Calculations" TextAlign="Center" TextVerticalAlign="Middle" Font="4" FontColor="0" BackColor="A0A0A0" ShowBackColor="True"/>
<TextBlock Name="instance110447" X="140" Y="70" Width="100" Height="32" Alpha="255" Text="Temp Range" TextAlign="Center" TextVerticalAlign="Middle" Font="3" FontColor="0" BackColor="000000" ShowBackColor="False"/>
<TextBox Name="tempRange" X="150" Y="100" Width="80" Height="32" Alpha="255" Text="0.0" TextAlign="Right" Font="4" FontColor="000000"/>
<TextBlock Name="instance112148" X="240" Y="70" Width="100" Height="32" Alpha="255" Text="Temp Offset" TextAlign="Center" TextVerticalAlign="Middle" Font="3" FontColor="0" BackColor="000000" ShowBackColor="False"/>
<TextBox Name="tempOffset" X="250" Y="100" Width="80" Height="32" Alpha="255" Text="0.0" TextAlign="Right" Font="4" FontColor="000000"/>
<CheckBox Name="applyDensity" X="405" Y="29" Width="32" Height="32" Alpha="255" Checked="False"/>
<TextBlock Name="instance51805" X="20" Y="30" Width="100" Height="32" Alpha="255" Text="Temp Coeff Per deg C" TextAlign="Left" TextVerticalAlign="Middle" Font="2" FontColor="0" BackColor="000000" ShowBackColor="False"/>
<TextBox Name="tempCoeffText" X="119" Y="29" Width="100" Height="32" Alpha="255" Text="0.000000" TextAlign="Right" Font="4" FontColor="000000"/>
</Window>
</Glide>
instance51805 and tempCoeffText get reset. See the attached image from the editor window.
The XML was originally created with the Glide online editor.
It seems to be related to the data being after the CheckBox entry. If I move it so that the check box is the last entry it works.
It also does it with this simple form so it is repeatable.
<Window Name="instance115" Width="320" Height="240" BackColor="FFFFFF">
<CheckBox Name="test" X="117" Y="66" Width="32" Height="32" Alpha="255" Checked="False"/>
<TextBlock Name="testEdit" X="89" Y="28" Width="100" Height="32" Alpha="255" Text="TextBlock" TextAlign="Left" TextVerticalAlign="Middle" Font="4" FontColor="0" BackColor="000000" ShowBackColor="False"/>
</Window>
</Glide>
Also note that because of this, you can’t have more than 1 checkbox or it will mess up all those below the first one. This fails too.
<TextBlock Name="testLabel" X="90" Y="29" Width="100" Height="32" Alpha="255" Text="TextBlock" TextAlign="Left" TextVerticalAlign="Top" Font="4" FontColor="0" BackColor="000000" ShowBackColor="False"/>
<CheckBox Name="check1" X="117" Y="66" Width="32" Height="32" Alpha="255" Checked="False"/>
<CheckBox Name="check2" X="116" Y="119" Width="32" Height="32" Alpha="255" Checked="False"/>
</Window>
</Glide>
