hmmm just stumbled on something that has be a bit ???
Changed a few lines of code in multiple projects in same solution and the could not build the TinyCLR Library all the other projects depended on.
Had me chasing tail for a bit!! As didnt keep track of changes and OF COURSE I have no Version Control set up as … well…
Anyway, found it, and it turns out if I reproduce same code in a NEW Blank TinyCLR Library v1.0.0 TinyCLR.Core (referenced only), VS2019 v16.2.5 I get same error
Can anyone else reproduce?
namespace TinyCLRClassLibrary1
public class Class1
private void RemoveCRLF(string text)
string aString = “Weeee”;
byte bBytes = new byte[4] {1,2,3,4 };
foreach (byte b in bBytes)
foreach (char c in aString) /* This is what cause emit error */
Build and get Error
"CS7038 Failed to emit module ‘TinyCLRClassLibrary1’
Remark out the foreach(char … and builds
Am I missing something obvious?
Main reason for posting it was to see if this is an issue with TinyCLR libs?
Think I have found a few other strange things with some FIelds and Properties using Reflection relating to ‘String’ Types.
Seeing some weird Getter Methods on String.Length and String.Empty and others while trying to implement a JSon DeSerialiser back into POCO’s …
Im starting to think its related and just wanted to get peoples feedback. Its a non common error for this line of code, just to cause that.
If I remember right from when I last looked into this it is because string does not implement IEnumerable or the pattern expected by foreach. We have an issue open to look into that in the future.
