Exposing SPI3 on the FEZ Feather
I needed a third hardware SPI bus for a project and wasn’t using the onboard Wi-Fi module, so I decided to expose the SPI3 signals from the Wi-Fi module itself.
The SPI3 lines (SCLK, MOSI and MISO) are available on the module edge. I soldered a small FPC connector to those pads and routed the signals through a standard FFC cable to an inexpensive FPC-to-DIP adapter board.
This provides access to SPI3 using a regular header while keeping the modification clean and compact.
Benefits:
  • Access to the third hardware SPI controller
  • Clean wiring with no flying jumper wires
  • Easily reversible
  • Minimal impact on the original board layout
If Wi-Fi is needed later, I simply unplug the FFC cable and use the module normally again.
The SPI controller is already present on the STM32. This modification only exposes signals that are otherwise occupied by the onboard Wi-Fi module.
Maybe this will be useful to anyone who needs an additional hardware SPI interface and doesn’t require Wi-Fi in a particular project…
