In another post, I showed how to create and mount a new partition or partitions on an Endpoint device. This post will show how to expand the Endpoint application partition to the full size of your SD card. Which approach, or blend of approaches you choose will depend on the needs of your application. For simplicity, you might want a single large partition. Or, you might choose to use a separate ext4 partition, or even a raw partition, for storing logs or data streams at maximum efficiency.
Whatever design you choose, you should always resize partition 7 before creating or modifying partitions 8 or above.
- Your dotnet app must not be running. Make sure it isn’t by using the Endpoint tool to disable run-at-startup, and then reboot your Endpoint board. It’s best if you start with a newly created SD card, or at least one that doesn’t have anything irreplaceable on it as typos or errors here might require that you re-image your SD card. It’s also best that you not reboot in between these steps.
- Connect to your Endpoint with ssh :
ssh 192.168.82.2 - List the current partitions with :
fdisk -lDisk /dev/mmcblk1: 7.4 GiB, 7948206080 bytes, 15523840 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: B27368D9-649F-47CD-80E2-C6B0A4C16DC0 Device Start End Sectors Size Type /dev/mmcblk1p1 34 1057 1024 512K Linux filesystem /dev/mmcblk1p2 1058 2081 1024 512K Linux filesystem /dev/mmcblk1p3 2082 10273 8192 4M Linux filesystem /dev/mmcblk1p4 10274 1058849 1048576 512M Linux filesystem /dev/mmcblk1p5 1058850 2107425 1048576 512M Linux filesystem /dev/mmcblk1p6 2107426 4204577 2097152 1G Linux filesystem /dev/mmcblk1p7 4204578 6252577 2048000 1000M Linux filesystem - Take note of the “Start” block number for p7. In my case, it is 4204578.
- Unmount p7 with
umount /root/.epdata - Run fsdisk with :
fsdisk /dev/mmcblk1 - Delete partition 7:
Command (m for help): d Partition number (1-7, default 7): 7 Partition 7 has been deleted. - Write the new partition table:
Command (m for help): w The partition table has been altered. Syncing disks. - Run fsdisk again :
fsdisk /dev/mmcblk1 - Create a new partition 7 and write that out. It is essential that you manually enter the First Sector value using the same number noted above in step 4:
Command (m for help): n Partition number (7-128, default 7): 7 First sector (4204578-15523806, default 4206592): 4204578 Last sector, +/-sectors or +/-size{K,M,G,T,P} (4204578-15523806, default 15523806): Created a new partition 7 of type 'Linux filesystem' and of size 5.4 GiB. Partition #7 contains a ext4 signature. Do you want to remove the signature? [Y]es/[N]o: N Command (m for help): w The partition table has been altered. Syncing disks. - Now we have a partition that is the right size, but the filesystem (directory) structure within that partition still thinks it is the old size, so let’s run resize2fs to update the filesystem. Be sure to type the full partition name with p7 on the end in the resize2fs command: /dev/mmcblk1p7:
# resize2fs /dev/mmcblk1p7 resize2fs 1.46.5 (30-Dec-2021) Resizing the filesystem on /dev/mmcblk1p7 to 1414903 (4k) blocks. The filesystem on /dev/mmcblk1p7 is now 1414903 (4k) blocks long. - Now, let’s remount our filesystem :
mount /dev/mmcblk1p7 /root/.epdata - A
dfcommand will show the new wide open spaces we have for our application and data:# df Filesystem 1K-blocks Used Available Use% Mounted on /dev/root 419444 198323 194088 51% / devtmpfs 154820 0 154820 0% /dev tmpfs 220868 0 220868 0% /dev/shm tmpfs 220868 228 220640 0% /tmp tmpfs 220868 32 220836 0% /run /dev/mmcblk1p6 757680 736500 0 100% /root/.epnet /dev/mmcblk1p7 5554812 20352 5235096 0% /root/.epdata - You should now be able to reboot and .epdata should be automatically remounted for you because it is listed in /etc/fstab. My SD card is an 8Gb card, and this shows around 5.5Gb of space that will be available for my application and any data that it saves in or below the app directory. Compare the mmcblk1p7 output from
fdisk -lbelow to the output from step 3:Disk /dev/mmcblk1: 7.4 GiB, 7948206080 bytes, 15523840 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: B27368D9-649F-47CD-80E2-C6B0A4C16DC0 Device Start End Sectors Size Type /dev/mmcblk1p1 34 1057 1024 512K Linux filesystem /dev/mmcblk1p2 1058 2081 1024 512K Linux filesystem /dev/mmcblk1p3 2082 10273 8192 4M Linux filesystem /dev/mmcblk1p4 10274 1058849 1048576 512M Linux filesystem /dev/mmcblk1p5 1058850 2107425 1048576 512M Linux filesystem /dev/mmcblk1p6 2107426 4204577 2097152 1G Linux filesystem /dev/mmcblk1p7 4204578 15523806 11319229 5.4G Linux filesystem
