Exogear’s Exovolt Plus ‘stackable’ battery pack claims to be the first of its kind
awesome… and it looks nice to boot!
That is perty… would look even better with a solar panel chargin’ it up
@ ransomhall - might take a fair bit of sunshine to top up 5,200 mAh - we would be knackered over here in the UK
@ Justin - Depends on how fast you discharge it. I’ve been working on just such a solution… not nearly as pretty, though. Mine does fairly well with one 6V 3.7W panel, and I live in a similar climate. We have and an exceptionally dry and sunny summer, though, which has probably made me a bit more optimistic than I should be about actual charge times.
“knackered” - love it! Is that an acceptable term to use in the presence of delicate ears, or is it more PG-13 rated?
@ ransomhall - Would be interested to see your solution, i do try to be politically correct with all the youngsters around but being from downunder i would have probably used a different term normally
Looks like they’re designed by Apple
@ WouterH - let the suing begin
I keep forgetting you’re here in the UK
@ ransomhall - that’s a cool project
@ HughB - don’t hold that against me but on a lighter note I am injecting kiwiisms into the office culture
Does having the battery in the heat of the day effect it at all? Looks like you’ve got the case vented.
@ mhectorgato - Not anymore! The lipo charger has a spot to add a thermistor to slow down or stop charging if it gets too hot. I poked a hole in the outer plastic casing on the lipo and put the thermistor right next to the cells. I did have it shut down once from heat because the thermistor was wedged between the panel and the lipo, and only the panel actually got too hot. The battery was fine. I’ve since moved the thermistor to the other side of the battery and no more “overheating” has occured. Yes, the enclosure is (well) vented. A little low power fan that kicked on at some warm temp would be a great addition.
Remindes of of the stackabe power supplies on the Thermal Dynamics ‘Stak Pak’ plasma cutter from 20 odd years ago. It was a neat concept, one control unit, and up to ‘n’ power units, but it tended to blow up an awful lot.
