When I use the “tab” to automatically generate the ButtonEventHandler, I get
button.ButtonPressed += button_ButtonPressed;
void button_ButtonPressed(Button sender, Button.ButtonState state)
Debug.Print("Program test");
But it should be
button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
How to solve it?
Thanks.
It is correct. VS2012 creates events different from VS2010. The code will still compile and work if you use either version.
To be fair to Tzu Hsuan, I was surprised by this myself when I moved to VS2012
Without knowing about it, you would think this was an error.
Mike
October 1, 2013, 6:42am
4
this syntax for event registration has been in C# since the second generation of the language. VS2012 is now using this shorter form. I consider this a non-event.
Justin
October 1, 2013, 6:47am
5
And here i was under the impression that .Net was event driven :whistle:
simple and stupid question, but still thanks for all your help.
