I am using Fez Spider I kit with ethernetJ11D module and trying to run following code with static IP. All the ip, gateway and dns are successfully assigned and every thing seems OK, but when go into the browser and enter the ip, port and event name “hello”, nothing shows up there.
Debugger shows following output.
Using mainboard GHI Electronics FEZ Spider version 1.0
Program Started
Network is Up with following properties
IP:192.168.0.8
Web server started at http://192.168.0.8:80/
Dns:8.8.8.8
Dns:8.8.4.4
IP Address: 192.168.0.8
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
using System.Net;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using System.Net.Sockets;
namespace CameraEthernet
public partial class Program
Gadgeteer.Networking.WebEvent hello;
Gadgeteer.Networking.WebEvent takePicture;
Gadgeteer.Networking.WebEvent seePicture;
GT.Picture pic = null;
ethernetJ11D.NetworkInterface.Open();
ethernetJ11D.UseThisNetworkInterface();
NetworkInterface[] networkInterfaces = NetworkInterface.GetAllNetworkInterfaces();
// loop through each interface, assign an IP accordingly
foreach (NetworkInterface ni in networkInterfaces)
if (ni.NetworkInterfaceType == NetworkInterfaceType.Ethernet)
ni.EnableStaticIP("192.168.0.8" , "255.255.255.0" , "192.168.0.1");
ni.EnableStaticDns(new string[] { "8.8.8.8" , "8.8.4.4" });
ethernetJ11D.NetworkUp += new GTM.Module.NetworkModule.NetworkEventHandler(ethernet_NetworkUp);
ethernetJ11D.NetworkDown += new GTM.Module.NetworkModule.NetworkEventHandler(ethernet_NetworkDown);
camera.PictureCaptured += new Camera.PictureCapturedEventHandler(camera_PictureCaptured);
void camera_PictureCaptured(Camera sender, GT.Picture picture)
pic = picture;
void ethernet_NetworkUp(GTM.Module.NetworkModule sender, GTM.Module.NetworkModule.NetworkState state)
Debug.Print("Network is Up with following properties");
Debug.Print("IP:" + ethernetJ11D.NetworkSettings.IPAddress.ToString());
Gadgeteer.Networking.WebServer.StartLocalServer(ethernetJ11D.NetworkSettings.IPAddress , 80);
foreach (string s in sender.NetworkSettings.DnsAddresses)
Debug.Print("Dns:" + s);
var NetworkSettings = ethernetJ11D.NetworkSettings;
Debug.Print("IP Address: " + NetworkSettings.IPAddress);
Debug.Print("Subnet Mask: " + NetworkSettings.SubnetMask);
Debug.Print("Gateway: " + NetworkSettings.GatewayAddress);
hello = Gadgeteer.Networking.WebServer.SetupWebEvent("hello");
hello.WebEventReceived += new WebEvent.ReceivedWebEventHandler(hello_WebEventReceived);
button.TurnLedOn();
takePicture = Gadgeteer.Networking.WebServer.SetupWebEvent("takepicture");
takePicture.WebEventReceived += new WebEvent.ReceivedWebEventHandler(takePicture_WebEventReceived);
seePicture = Gadgeteer.Networking.WebServer.SetupWebEvent("seepicture");
seePicture.WebEventReceived += new WebEvent.ReceivedWebEventHandler(seePicture_WebEventReceived);
void ethernet_NetworkDown(GTM.Module.NetworkModule sender , GTM.Module.NetworkModule.NetworkState state)
button.TurnLedOff();
Debug.Print("Network Down");
void seePicture_WebEventReceived(string path, WebServer.HttpMethod method, Responder responder)
if (pic != null)
responder.Respond(pic);
responder.Respond("Take picture first");
void takePicture_WebEventReceived(string path, WebServer.HttpMethod method, Responder responder)
responder.Respond("Taking picture");
camera.TakePicture();
void hello_WebEventReceived(string path, WebServer.HttpMethod method, Responder responder)
Debug.Print("Hello world");
responder.Respond("Hello world");
