Hi
I have just received an ethernet shield, but I get the following exception when trying different code samples(complete projects).
I have tried it on two different Domino boards (running 04.03.00).
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.0 SDK\Assemblies\GHIElectronics.NETMF.IO.dll’
#### Exception System.Exception - CLR_E_DRIVER_NOT_REGISTERED (2) ####
#### Microsoft.SPOT.Hardware.NativeEventDispatcher::.ctor [IP: 0000] ####
#### GHIElectronics.NETMF.System.InternalEvent::.cctor [IP: 000e] ####
#### Exception System.InvalidOperationException - 0x00000000 (2) ####
#### GHIElectronics.NETMF.FEZ.FEZ_System::GetSystemType [IP: 001c] ####
#### GHIElectronics.NETMF.FEZ._Checker::.cctor [IP: 0003] ####
An unhandled exception of type ‘System.InvalidOperationException’ occurred in FEZDomino_GHIElectronics.NETMF.FEZ.dll
Additional information: FEZ not detected!
Uncaught exception
The thread 0x2 has exited with code 0 (0x0).
I hope You can give me a hint on whats worng here or what to look for…
kind regards
Thomas
