hi all,
i have fe domino, mp3 shield + ethernet shield connected together.
i can play mp3 files without any problem, today i started to use ethernet shield, and found the code in code library… while using the code:
// Copyright (c) Microsoft Corporation. All rights reserved.
// Modified to work with GHI's Wiznet W5100 Ethernet (TCP/IP) libraries.
using System.IO;
using System.Text;
using GHIElectronics.NETMF.Net.NetworkInformation;
/// This program demonstrates how to use the .NET Micro Framework HTTP classes
/// to create a simple HTTP client that retrieves pages from several different
/// websites, including secure sites.
namespace HttpClientSample
public static class MyHttpClient
/// <summary>
/// Retrieves a page from a Web server, using a simple GET request.
/// </summary>
public static void ethernetMain()
byte[] mac = { 0x00, 0x26, 0x1C, 0x7B, 0x29,0xE8 };
WIZnet_W5100.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di10, (Cpu.Pin)FEZ_Pin.Digital.Di7, true); // WIZnet interface on FEZ Connect
//Dhcp.EnableDhcp(mac);
Dhcp.EnableDhcp(mac,"smgethernet");
Debug.Print("Network settings:");
Debug.Print("IP Address: " + new IPAddress(NetworkInterface.IPAddress).ToString());
Debug.Print("Subnet Mask: " + new IPAddress(NetworkInterface.SubnetMask).ToString());
Debug.Print("Default Getway: " + new IPAddress(NetworkInterface.GatewayAddress).ToString());
Debug.Print("DNS Server: " + new IPAddress(NetworkInterface.DnsServer).ToString());
// Print the HTTP data from each of the following pages.
PrintHttpData("http://www.google.com");
PrintHttpData("http://www.tinyclr.com/compare/");
/// <summary>
/// Prints the HTTP Web page from the given URL and status data while
/// receiving the page.
/// </summary>
/// <param name="url">The URL of the page to print.</param>
public static void PrintHttpData(string url)
// Create an HTTP Web request.
HttpWebRequest request =
HttpWebRequest.Create(url) as HttpWebRequest;
// Set request.KeepAlive to use a persistent connection.
request.KeepAlive = true;
// Get a response from the server.
WebResponse resp = null;
try
resp = request.GetResponse();
catch (Exception e)
Debug.Print("Exception in HttpWebRequest.GetResponse(): " +
e.ToString());
// Get the network response stream to read the page data.
if (resp != null)
Stream respStream = resp.GetResponseStream();
string page = null;
byte[] byteData = new byte[2048];
char[] charData = new char[2048];
int bytesRead = 0;
Decoder UTF8decoder = System.Text.Encoding.UTF8.GetDecoder();
int totalBytes = 0;
// allow 5 seconds for reading the stream
respStream.ReadTimeout = 5000;
// If we know the content length, read exactly that amount of
// data; otherwise, read until there is nothing left to read.
if (resp.ContentLength != -1)
for (int dataRem = (int)resp.ContentLength; dataRem > 0; )
Thread.Sleep(500);
bytesRead =
respStream.Read(byteData, 0, byteData.Length);
if (bytesRead == 0)
Debug.Print("Error: Received " +
(resp.ContentLength - dataRem) + " Out of " +
resp.ContentLength);
break;
dataRem -= bytesRead;
// Convert from bytes to chars, and add to the page
// string.
int byteUsed, charUsed;
bool completed = false;
totalBytes += bytesRead;
UTF8decoder.Convert(byteData, 0, bytesRead, charData, 0,
bytesRead, true, out byteUsed, out charUsed,
out completed);
page = new String(charData, 0, charUsed);
// Display the page results.
Debug.Print(page);
page = new String(
System.Text.Encoding.UTF8.GetChars(byteData));
// Read until the end of the data is reached.
// If the Read method times out, it throws an exception,
// which is expected for Keep-Alive streams because the
// connection isn't terminated.
try
Thread.Sleep(500);
bytesRead =
catch (Exception)
bytesRead = 0;
// Zero bytes indicates the connection has been closed
// by the server.
if (bytesRead == 0)
break;
out completed);
Debug.Print(page);
// Close the response stream. For Keep-Alive streams, the
// stream will remain open and will be pushed into the unused
// stream list.
resp.Close();
i get the
Network settings:
IP Address: 192.168.1.36
Subnet Mask: 255.255.255.0
Default Getway: 192.168.1.1
DNS Server: 192.168.1.1
i can ping this ip, i get response…
while getting ping responses, i can see the leds blinking on the ethernet shield…
but when i want to get any url result, i get error…
where/what is the problem?
