AlbeNET
November 18, 2015, 8:12am
1
Whith the latest version of the official SDK from GHI is still required a custom firmware with the Ethernet support for this board?
If yes, where i can download the famous “Ethernet firmware” and what are the best practices to enable Ethernet communication for this board?
@ AlbeNET - Older firmware (4.2) is located in the installation path:
C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.2 SDK\Firmwares\FEZ Hydra\Ethernet
In 4.3 it has been unified into one.
@ andre.m - I am not sure now. I am pretty sure I’ve seen the post where it was stated.
On the other hand Benny the plant is storing his vitals data in Azure through Hydra.
You are right. I misread an older post.
Updated my earlier reply.
AlbeNET
November 19, 2015, 3:45am
5
k so there is JUST ONE FIRMWARE. Right? and if i use the one from the 2015 R1 SKD it includes the Ethernet stuff…
But i tried to use this code:
Microsoft.SPOT.Net.NetworkInformation.NetworkChange.NetworkAvailabilityChanged += networkChange
netif = new EthernetENC28J60(SPI.SPI_module.SPI1, Cpu.Pin.GPIO_Pin1, Cpu.Pin.GPIO_Pin2, Cpu.Pin.GPIO_Pin3);
netif.Open();
netif.EnableStaticIP("192.168.1.180","255.255.255.0", "192.168.1.254");
netif.EnableStaticDns(new string[]{"192.168.1.254","8.8.8.8"} );
But the event handler network change never fired and i cannot even ping the board.
Is that correct what i’m doing?
AlbeNET
November 19, 2015, 8:09am
6
@ andre.m - It’s connected on socket 3.
That configuration is valid for Cerberus?
Definitely wrong pins. Use static class from GHI.Pins assembly: FEZHydra.Socket3.Pin3, etc. Or the gpio number directly. Here is one for Hydra Socket3
public static class Socket3
/// <summary>Pin definition.</summary>
public const Cpu.Pin Pin3 = (Cpu.Pin)40;
public const Cpu.Pin Pin4 = (Cpu.Pin)41;
public const Cpu.Pin Pin5 = (Cpu.Pin)44;
public const Cpu.Pin Pin6 = (Cpu.Pin)45;
public const Cpu.Pin Pin7 = (Cpu.Pin)26;
public const Cpu.Pin Pin8 = (Cpu.Pin)25;
public const Cpu.Pin Pin9 = (Cpu.Pin)27;
/// <summary>SPI definition.</summary>
public const SPI.SPI_module SpiModule = SPI.SPI_module.SPI1;
AlbeNET
November 20, 2015, 3:40am
8
And now? who i can trust?
eheh i will try this hints anyway! Thanks guys! Really appreciated.
When i’ll be able to make it works i’ll probably create a code share.
I’m trying to use the Maker Channell of IFTTT (https://ifttt.com/maker ) to rise some Events from my board.
AlbeNET
November 20, 2015, 4:42am
9
@ andre.m - it seems just partially… not the cpu pin number.
Anyway andre.m thank you for your extraordinary diligence in countering what I write.
You complained that I brought more 'similar questions in the post several times but your behavior is not much better.
I like to be frank, if I make a silly question is perhaps because there is no clear answer.
If this strikes you I’m so sorry.You can not read my every post and not give me more 'help.
I, however, will try to consolidate all this information that you gave me in a post accessible even to people like me who has tried to look at various posts without finding a definitive solution to operate the Hydra Ethernet with the last firmware 4.3
AlbeNET
November 20, 2015, 6:01am
10
@ andre.m - Excellent! i’ll try to use the static definition in FEZHydra.Socket3
Then i assume that for Cerberos i can use the same approach with its own static definition. Now just wondering if there is any specific spi port to be used or any is fine
AlbeNET
November 20, 2015, 8:34am
11
@ andre.m - I mean the socket. sorry misconfusion.
I mean the Cerberus has 2 socket S as well. I didn’t yet dig if they are connected to the same SPI port as well or not… i’ll double check that!
AlbeNET
November 20, 2015, 9:12am
12
ok now i’m going to try this:
var ethernet = new GHI.Networking.EthernetENC28J60(
GHI.Pins.FEZHydra.Socket3.SpiModule,
GHI.Pins.FEZHydra.Socket3.Pin6,
GHI.Pins.FEZHydra.Socket3.Pin3,
GHI.Pins.FEZHydra.Socket3.Pin4
AlbeNET
November 20, 2015, 9:42am
13
EXCELLENT!!
it worked
Now i got an exception on this code:
/// <summary>
/// Trigger IFTTT event
/// </summary>
/// <param name="eventName"></param>
/// <param name="value1"></param>
/// <param name="value2"></param>
/// <param name="value3"></param>
/// <returns></returns>
public static string TriggerIFTTTEvent(string eventName, string secret, string value1 = null, string value2 = null, string value3 = null)
//create the right URL basing on the Trigger Name
string requestUrl = "https://maker.ifttt.com/trigger/" + eventName + "/with/key/"+ secret;
HttpWebRequest request = (HttpWebRequest)WebRequest.Create(requestUrl);
string postData = string.Empty;
if (value1 != null || value2 != null || value3 != null)
postData += "{";
if (value1 != null)
postData += @ """value1"":""" + value1 + "\"";
if (value2 != null)
if (value1 != null)
postData += ",";
postData += @ """value2"":""" + value2 + "\"";
if (value3 != null)
if (value1 != null || value2 != null)
postData += ",";
postData += @ """value3"":""" + value3 + "\"";
postData += "}";
byte[] data = Encoding.UTF8.GetBytes(postData);
//Set parameters of web request for HTTP POST
request.Method = "POST";
request.ContentType = "application/json";
request.ContentLength = data.Length;
request.KeepAlive = false;
if (data.Length > 0)
Stream postDataStream = request.GetRequestStream();
postDataStream.Write(data, 0, data.Length);
postDataStream.Close();
HttpWebResponse response = request.GetResponse() as HttpWebResponse;
return response.StatusDescription;
when i try to execute this line:
[quote]#### Exception System.Net.WebException - 0x00000000 (5) ####
#### Message:
#### System.Net.HttpWebRequest::GetResponse [IP: 00d3] ####[/quote]
WebException should have Status and Response fields. What do you have there?
AlbeNET
November 20, 2015, 10:34am
15
With this code i solved…
public static void TriggerIFTTTEvent(string eventName, string secret, string value1 = null, string value2 = null, string value3 = null)
string requestUrl = "https://maker.ifttt.com/trigger/" + eventName + "/with/key/" + secret;
postData += "{";
if (value1 != null)
if (value2 != null)
if (value1 != null)
postData += ",";
if (value3 != null)
postData += ",";
postData += "}";
Gadgeteer.Networking.HttpRequest request = null;
Gadgeteer.Networking.POSTContent content = null;
if (postData != null)
// Create POST content
content = Gadgeteer.Networking.POSTContent.CreateTextBasedContent(postData);
// Create the request
request = Gadgeteer.Networking.HttpHelper.CreateHttpPostRequest(
requestUrl // the URL to post to
, content // the form values
, "application/json" // the mime type for an HTTP form
request = Gadgeteer.Networking.HttpHelper.CreateHttpGetRequest(requestUrl);
request.ResponseReceived += request_ResponseReceived;
//// Post the form
request.SendRequest();
static void request_ResponseReceived(Gadgeteer.Networking.HttpRequest sender, Gadgeteer.Networking.HttpResponse response)
Debug.Print(response.StatusCode);
AlbeNET
November 20, 2015, 10:35am
16
@ andre.m - i didn’t get the full exception just that!
