I hope I’m not being stupid, but anytime I plug in the ethernet module, the whole system dies, i.e. the power lights on the spider and the usbclient go out and the device is disconnected from windows. As soon as I unplug in the module, the system lights up and reboots.
I’ve tried, plugging the module both before and after the usb cable, and I’ve tried an external power source (I thought initially there was not enough power) and neither makes a difference. Even plugging the ethernet into the usbclient directly caused it to stop working.
Lets not forget that there was mention here previously that modules are not meant to be hot-plugged. The way you describe the problem seems like you’re hot-plugging? Can you try powering up with everything connected and see if that is any different?
Socket type of that sytech is Z not S. This is very sad and limits the use of their module. If they designed it properly with S type then this module could have been used on almost any gadgeteer mainboard.
Z = vendor specific.
S = SPI, which is what the ethernet EMC28J60 chip used on that module.
Now, even if a module is type Z, it MUST be safe to handle accidental use. Boards shouldn’t short!
