What SPI clock speed does the Hydra use to communicate with the Ethernet ENC28 Module ?
Not sure but why do you need to know? If you trying to determine the transfer speed, the clock frequency will not give you any good info.
As this is a very new feature, we haven’t done any performance testing.
i was just curious in the thought of the Ethernet SPI clock speed. If it was say 10mhz, and i had another slower SPI device on the same SPI bus using a different CS pin, does .netmf change the clock rates as needed to talk to both deices ?
Now I know, so your question is “does .netmf change the clock rates as needed to talk to both deices ?”
And answer is yes.
Thanks Gus
