Recently I tested my code with the latest TinyCLR release (2.2.1.2000) and I found a bug in the ethernet function.
When the device receives a “POST” command, I check the “context.Request.RawUrl.ToUpper()” content, if it contains a file upload request, I check the “Content-length” value, I create a buffer of this length and I read the chunks to fill the buffer:
int len = int.Parse(context.Request.Headers[“Content-Length”]);
byte buffer = new byte[len];
int index = 0;
while (index < len)
int leng = (int)context.Request.InputStream.Length;
context.Request.InputStream.Read(buffer, index, leng);
index += leng;
This method works perfectly with the older version of the TinyCLR (2.2.0.5100).
With the new TinyCLR, the InputStream.Read(…) instruction returns more than the “Content-Length” bytes (and that causes an error as I’m trying to write to the “buffer” outside of its boundaries.
In order to find out why, I “expanded” the buffer size to read all the data and found that in the buffer there is sometimes an unwanted sequence of bytes, in my case this: “------WebKitFormBoundaryLeVuml8JE0325V6D Content-Disposition: form-data; name="uploadFi” string
that repeats several times and so the sent file is dirty and longer than it should be.
For the moment, I must stay with the old version of TinyCLR.
Please let me know when a solution to this problem will be available.
Thank you in advance for any help.
Vittorio
Hi Dat,
I don’t use the HttpWebRequest in my implementation. I use the HttpListener. Upon a request (listener != null) I get the context and I start a thread that manages the request (where I set/check the cookies, I test the method and I handle the “POST” and “GET” requests checking the “context.Request.RawUrl” content. With TinyCLR 2.2.0.5100 it works like a charme. With 2.2.1.2000 I find extra characters in the input stream. In fact, I receive more bytes than the quantity given in the “Content-Length” attribute. The position of the extra bytes is not always the same.
Thank you,
Vittorio
Hello, we have checked this issue and sorry to say: “Could not reproduce”.
Could you please provide a simple code that we can reproduce? Base on your information, we made a simple test and it looks good to us
SITCore:
static void DoTestHttpListener()
//Create a listener.
HttpListener listener = new HttpListener("http", 80);
listener.Start();
Debug.WriteLine("Start listening...");
try
var context = listener.GetContext();
var inputStream = context.Request.InputStream;
var bytes = new byte[inputStream.Length];
var read = inputStream.Read(bytes, 0, (int)inputStream.Length);
Debug.WriteLine(string.Format("read {0}", read));
catch (Exception)
Thread.Sleep(10);
PC:
static async void DoTestHttpClient()
var client = new HttpClient();
client.BaseAddress = new Uri("http://192.168.86.100");
await using var stream = System.IO.File.OpenRead("./ola.bin");
using var request = new HttpRequestMessage(HttpMethod.Post, "file");
using var content = new MultipartFormDataContent
{ new StreamContent(stream), "file", "ola.bin" }
var result = Task.Run(() => {
request.Content = content;
client.SendAsync(request);
Console.WriteLine("Done");
Thread.Sleep(-1);
And result is 441 as we tested:
Send:
Received and read:
We need you to provide simple code to see the issue.
