karamafrooz
Not sure if this is a suitable way to post but…
I had issues with using PersistentStorage but never followed up on finding out why.
I will post code that works on my Raptor that does not use PersistentStorage.
No expert here but the code worked for my use. I did have a issue with debugging but not with reading/writing folders/files to a USB Card reader that contains a 16 Gig SD (formatted using the Windows 8 formatter).
If you want I can send you the application in a zip for your testing.
YES, I realize that this does not answer your question about using PersistentStorage.
NOTE: No pro here so all I can say it works for me.
using System.Collections;
using Microsoft.SPOT.Touch;
using Microsoft.SPOT.IO;
using System.IO; //IO Stream Reader/Writer
using System.Xml; //XML
using Gadgeteer;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using GHI.Premium.USBHost;
using GHI.Premium.System;
My Raptor info:
Loader (TinyBooter) version information:
4.2.11.1 on this computer.
4.2.11.1 on this device.
>>> The Loader (TinyBooter) is up to date. <<<
Firmware (TinyCLR) version information:
>>> The Firmware (TinyCLR) is up to date. <<<
Please wait for the device to reboot... Done.
// Using Windows 8.1 64-bit with latest updates available at this time.
// Using Microsoft Visual Studio Express 2012 for Desktop with all known updates.
// Using Windows 7 Home Premium 64-bit with all known updates
// My results are the same on either system used
Microsoft Visual Studio Express 2012 for Windows Desktop
Version 11.0.60610.01 Update 3
Microsoft .NET Framework
Version 4.5.51641
Installed Version: Desktop Express
Team Explorer for Visual Studio 2012 05695-004-0030004-02248
Microsoft Team Explorer for Visual Studio 2012
Visual Basic 2012 05695-004-0030004-02248
Microsoft Visual Basic 2012
Visual C# 2012 05695-004-0030004-02248
Microsoft Visual C# 2012
Visual C++ 2012 05695-004-0030004-02248
Microsoft Visual C++ 2012
Microsoft .NET Micro Framework v4.3
Microsoft .NET Micro Framework SDK v4.3
Version 4.3.0.0
NuGet Package Manager 2.7.41101.299
NuGet Package Manager in Visual Studio. For more information about NuGet, visit http: //docs.nuget.org/.
SQL Server Data Tools 11.1.20828.01
Microsoft SQL Server Data Tools
//Some 'borrowed' code use in here (obtained from codeshare)
namespace USBHostTest
public partial class Program
static Display_T35 display;
static Font fontSmall;
static Font fontLarge;
static bool usbHostAvailable = false;
public static string fileText = "This is a test string for reading and writing to media";
display = display_T35;
fontSmall = Resources.GetFont(Resources.FontResources.small);
fontLarge = Resources.GetFont(Resources.FontResources.NinaB);
//The usbHost.USBDriveConnected event is received if media is inserted
usbHost.USBDriveConnected += new UsbHost.USBDriveConnectedEventHandler(usbHost_USBDriveConnected);
usbHost.USBDriveDisconnected += new UsbHost.USBDriveDisconnectedEventHandler(usbHost_USBDriveDisconnected);
display_T35.SimpleGraphics.BackgroundColor = Colors.LightGray;
display_T35.SimpleGraphics.DisplayText("Program is running", fontLarge, Colors.Black, 10, 10);
#region USBHost events
//Save for further use
private static GT.StorageDevice savedUSBDrive = null;
private static VolumeInfo savedVolInfo = null;
//I am using a USB Card reader that contains a 16 Gig SD (formatted using the Windows 8 formatter)
//This event is received on application start if media is present (And whenever media is inserted)
static void usbHost_USBDriveConnected(UsbHost sender, GT.StorageDevice USBDrive)
//Assuming that it is a Flash device or SD to USB card reader
usbHostAvailable = true;
display.SimpleGraphics.DisplayText("USB Host Device Connected - Volume: " + USBDrive.Volume.Name, fontLarge, Colors.Black, 10, 30);
//Debug.Print("USB Host connect event: Device Is Connected - Volume: " + USBDrive.Volume.Name);
savedUSBDrive = USBDrive;
savedVolInfo = USBDrive.Volume;
//Blue LED on the Raptor mainboard
//Turn ON to notify that a storage device was found
Program.Mainboard.SetDebugLED(true);
//Set a breakpoint on the following bool and use: Restart Ctrl+Shift+F5
//Debugging will work up to this point
bool stopHereDebuggingOK = true;
//From this point on a 'reset' of the Raptor is needed to restart the application
//Creat some Directories(Folders)
try
Thread.Sleep(1000);
USBDrive.CreateDirectory("\\CalStrings");
Debug.Print("Created Directory: " + "\\CalStrings");
catch (Exception err)
Debug.Print("Failed to create \\CalStrings : " + err.Message);
return;
//Set a breakpoint on the following bool and use Restart Ctrl+Shift+F5
//Debugging fails here (After writing to storage device)
bool stopHereDebuggingFails = true;
//All files are made as intended
try
Thread.Sleep(1000);
USBDrive.CreateDirectory("\\CalXML");
Debug.Print("Created Directory: " + "\\CalXML");
Debug.Print("Failed to create \\CalXML : " + err.Message);
return;
string[] ListDirectories = USBDrive.ListDirectories("\\");
string listdirectories = string.Empty;
foreach (string dir in ListDirectories)
listdirectories += ("\t" + dir + "\r\n");
Debug.Print("Root Directories:\r\n" + listdirectories);
string[] RootDirectoryFiles = USBDrive.ListRootDirectoryFiles();
string rootfiles = string.Empty;
foreach (string files in RootDirectoryFiles)
FileInfo Fileinfo = new FileInfo(USBDrive.RootDirectory + "\\" + files);
rootfiles += (new string(' ', USBDrive.RootDirectory.Length) +
files + " size: " + rootfiles.Length + " bytes\r\n");
Debug.Print("Root Files:\r\n" + rootfiles);
if (usbHostAvailable)
//Want bytes?
string TextContent = String.Empty;
//TextContent = "160,32,32,288,288";
TextContent =
"<?xml version=\"1.0\"?>\r\n<calib>\r\n\t<sx>thesxvalue</sx>\r\n\t<sy>thesyvalue</sy>\r\n\t<cx>thecxvalue</cx>\r\n\t<cy>thecyvalue</cy>\r\n</calib>";
byte[] bytes = System.Text.Encoding.UTF8.GetBytes(TextContent);
try
USBDrive.WriteFile(@ "testCalFile.xml", bytes);
Debug.Print(err.ToString());
return;
Debug.Print("Wrote: testCalFile.xml to USB");
try
//Use wrong file name
byte[] fileHandle = USBDrive.ReadFile(@ "testCalFile.xml");
if (!(readXMLVal(fileHandle, "sx") == null))
string valuereturned = readXMLVal(fileHandle, "sx");
Debug.Print("Value sx from XML file found: " + valuereturned);
if (!(readXMLVal(fileHandle, "sy") == null))
string valuereturned = readXMLVal(fileHandle, "sy");
Debug.Print("Value sy from XML file found: " + valuereturned);
if (!(readXMLVal(fileHandle, "cx") == null))
string valuereturned = readXMLVal(fileHandle, "cx");
Debug.Print("Value cx from XML file found: " + valuereturned);
if (!(readXMLVal(fileHandle, "cy") == null))
string valuereturned = readXMLVal(fileHandle, "cy");
Debug.Print("Value cy from XML file found: " + valuereturned);
return;
Debug.Print("Program tasks completed");
display.SimpleGraphics.DisplayText("Program tasks completed", fontLarge, Colors.Black, 10, 200);
//This event is not received on application start
static void usbHost_USBDriveDisconnected(UsbHost sender)
Debug.Print("Media was removed");
Program.Mainboard.SetDebugLED(false); //OFF
#endregion USBHost events
static StreamWriter GetFileStream(string filename)
StreamWriter Stream = null;
try
Stream = new StreamWriter(filename);
Debug.Print("StreamWriter Failed: " + filename);
Debug.Print("Msg: " + err.Message);
return Stream;
//Uses the string fileText (Contains text to write to FileName)
static Boolean WriteTextFile(string FileName)
StreamWriter Stream = GetFileStream(FileName);
if (null == Stream)
return false;
try
Stream.Write(fileText);
catch (Exception error)
Stream.Close();
Debug.Print("Failed to write " + FileName);
Debug.Print(error.Message);
return false;
Stream.Close();
Debug.Print("Write sucessful: " + FileName);
return true;
//Cycle through XML and find/return string readValue
static string readXMLVal(byte[] xmlData, string readValue)
Stream configStream = new MemoryStream(xmlData);
XmlReader configFileXML = XmlReader.Create(configStream);
while (!configFileXML.EOF)
while (configFileXML.NodeType != XmlNodeType.EndElement)
//Continue looking
configFileXML.Read();
//Check if the <Name> is what we are looking for ( <Name>Value</Name> )
if (configFileXML.Name.ToLower() == readValue.ToLower())
//Continue if there is no Value
//Continue looking
//Continue only if there is a Text node
if (configFileXML.NodeType == XmlNodeType.Text)
//Value was found so return it
return configFileXML.Value;
//Continue looking
//Continue looking
return null; //Return null if nothing found
Hope it helps
The image files show the errors with debugging but as I said, it did not cause any problems that I know of except for debug (I posted a issue on this)
Happy Holidays!
