.[quote] When it asks for DisplayModule.cs, you can just ignore it and step over that line.[/quote]
I tried but debugging crashes!
I have a similar problem with a clean project with the FEZ Hydra, but I don’t have any display in my project. It says:
Using mainboard GHI Electronics FEZHydra version 1.2
Updating display configuration. THE MAINBOARD WILL NOW REBOOT.
To continue debugging, you will need to restart debugging manually (Ctrl-Shift-F5)
and if you restart, it says the same. Infinite loop with no debugging. And I don’t have any display at all!
Firmware version is 4.2.6.2.
Has anyone found a solution?
