I have been seeing this message the whole day
[quote]Error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ’ , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , )’ at line 1
Query: DELETE FROM forum_unread WHERE id IN (, , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , , )[/quote]
Happens when I login.
I suspect something wrong with the code that updates the read/unread posts.
