I was hooking up devantech SRF10 through gedgeteer extender. The address I use was 0x70 according to 7bit and 8bit address difference. I managed to hook up the sensor and was able to write ranging command such as
buffer = new byte[] { 0x70, 0x00, 0x51};
int i = i2c.Write(buffer, 500);
Thread.Sleep(readDelay);
through I2CBus.
However I always get 1280 as distance when I read from buffer. Here is complete code I done in timer tick.
Yep, they’re quoting an 8-bit address (because they don’t understand I2C !!! Gah, when will they learn!?) so the 7-bit address is 0x70. Assuming you haven’t changed it on the device
Thank for your prompt’s reply. I have initially tried to construct I2CBus with 0xE0.
I received following error.
Using mainboard GHI Electronics FEZSpider version 1.0
Program Started
writing range
#### Exception System.ArgumentException - 0xfd000000 (1) ####
#### Message:
#### Microsoft.SPOT.Hardware.I2CDevice::Execute [IP: 0000] ####
#### Gadgeteer.Interfaces.I2CBus::Execute [IP: 001a] ####
#### Gadgeteer.Interfaces.I2CBus::Write [IP: 0012] ####
#### UltrasonicSample.Program::timer_Tick [IP: 002f] ####
#### Gadgeteer.Timer::dt_Tick [IP: 0018] ####
#### Microsoft.SPOT.DispatcherTimer::FireTick [IP: 0010] ####
#### Microsoft.SPOT.Dispatcher::PushFrameImpl [IP: 0054] ####
#### Microsoft.SPOT.Dispatcher::PushFrame [IP: 001a] ####
#### Microsoft.SPOT.Dispatcher::Run [IP: 0006] ####
#### Gadgeteer.Program::Run [IP: 0020] ####
A first chance exception of type ‘System.ArgumentException’ occurred in Microsoft.SPOT.Hardware.dll
Exception performing Timer operation
In one of the Arduino forum, Nicholas Zambetti http://www.zambetti.com wrote this.
// step 1: instruct sensor to read echoes
Wire.beginTransmission(112); // transmit to device #112 (0x70)
// the address specified in the datasheet is 224 (0xE0)
// but i2c adressing uses the high 7 bits so it’s 112
I used following constructor in my code. It can write with the i2cBus.
GT.Socket socket = GT.Socket.GetSocket(10, true, null, null);
i2c = new GTI.I2CBus(socket, 0x70, 40, null);
GT.Timer timer = new GT.Timer(500); // every second (1000ms)
timer.Start();
output windows shows
Program Started
writing range
previous 0
current 1280
writing range
previous 1280
current 1280
writing range
You need to use WriteRead method with two one byte buffers
First (“write”) buffer will have register number you want to read.
Second will have the returned byte after method is returned.
Thank all. After I changed the command with two bytes as per your advice and read from register 0x02 I managed to get it works.
Advise me where I could share this tiny little code.
