I’m getting an error when I try to use the UsbHost.KeyboardConnected event.
When I run the code and plug in a keyboard to the usb host I get in the debugger:
Using mainboard GHIElectronics-FEZSpider version 1.0
Program Started
UsbHost ERROR : USB device not supported.
What kind of keyboard does it take?
Maybe the gadgeteer driver doesn’t support keyboards?
Please start new “NETMF console project” (not gadgeteer, no designer) and try this GHI Electronics – Where Hardware Meets Software
Still missing type USBH_Device that I can’t find.
using GHIElectronics.NETMF.USBHost;
Error 5 The type or namespace name ‘USBH_Device’ could not be found (are you missing a using directive or an assembly reference?)
What a concept: Documentation!
Ok, I can make keyboard code work with a NETMF application, but when I try to use the KeyboardConnected event with the .NET Gadgeteer USBHost, I get an exception.
The following output and code from GHI documentation works fine with NETMF:
Hello World!
Device connected…
ID: 2700053376, Interface: 0, Type: 4
Device connected…
ID: 2700053376, Interface: 1, Type: 2
a
s
d
f
j
k
l
namespace NETMFKeyboard
static USBH_Keyboard keyboard;
Debug.Print(
Resources.GetString(Resources.StringResources.String1));
// Subscribe to USBH events.
USBHostController.DeviceConnectedEvent += DeviceConnectedEvent;
USBHostController.DeviceDisconnectedEvent += DeviceDisconnectedEvent;
// Sleep forever
static void DeviceConnectedEvent(USBH_Device device)
Debug.Print("Device connected...");
Debug.Print("ID: " + device.ID + ", Interface: " +
device.INTERFACE_INDEX + ", Type: " + device.TYPE);
if (device.TYPE == USBH_DeviceType.Keyboard)
keyboard = device as USBH_Keyboard;
keyboard.KeyDown += new USBH_KeyboardEventHandler(keyboard_KeyDown);
static void keyboard_KeyDown(USBH_Keyboard sender, USBH_KeyboardEventArgs args)
Debug.Print(args.KeyAscii.ToString());
static void DeviceDisconnectedEvent(USBH_Device device)
Debug.Print("Device disconnected...");
But similar code with .NET Gadgeteer application fails on KeyboardConnected event.
Error:
Program Started
The thread ‘’ (0x5) has exited with code 0 (0x0).
Code:
namespace TestKeyboard
public partial class Program
GHIElectronics.NETMF.USBHost.USBH_Keyboard keyboard;
usbHost.KeyboardConnected += new UsbHost.KeyboardConnectedEventHandler(usbHost_KeyboardConnected);
void usbHost_KeyboardConnected(UsbHost sender, GHIElectronics.NETMF.USBHost.USBH_Keyboard Keyboard)
keyboard = Keyboard;
keyboard.CharDown += new GHIElectronics.NETMF.USBHost.USBH_KeyboardEventHandler(keyboard_CharDown);
void keyboard_CharDown(GHIElectronics.NETMF.USBHost.USBH_Keyboard sender, GHIElectronics.NETMF.USBHost.USBH_KeyboardEventArgs args)
Debug.Print(args.Key.ToString());
Looks like you are having fun
Keep in mind that gadgeteer is few months old and what have is all beta. This will be much better in near future, thanks to GHI’s dedication and community contributions.
No complaints from me. I wouldn’t have figured it out nearly so quickly without the good examples in your documentation.
I am still getting this message…
Does it still fail in Gadgeteer but work in Micro Framework?
I dunno what the difference is…
