I try this sample:
http://www.ghielectronics.com/downloads/NETMF/Library%20Documentation/Index.html
I replaced “NAND” with “SD”… but doesn’t work!
The SD work fine with normal file system operation.
this is the error: (GHIElectronics.NETMF.SQLite 4.1.6.0)
#### Exception System.NotSupportedException - CLR_E_NOT_SUPPORTED (1) ####
#### Message:
#### GHIElectronics.NETMF.SQLite.Database::Open [IP: 0027] ####
