Error in pinout of SCM20260E?
I wired pin 26 (PA6) of the SCM20260E to my backlight, planning to use PWM to control the brightness. When I got the boards done and tried to set the PWM driver and select the PWM13.1 in software, as per the pinout, there is no PA6 and instead it offers me PF8, which when I check the schematic I see that it is also marked as PWM13.1
Obviously 1 of these is wrong so which is it? I am assuming PF8 is the correct one, without digging into the microcontroller datasheet.
Thank you, you are right, we will update doc
Remove PA6 as PWM13.1 · Issue #795 · ghi-electronics/Documentation
Hi Dat
Just a heads up. I posted about this at the weekend and found this one I reported back in 2024. Your docs are still out of date :face_savoring_food:
Also check the docs for the SCM20260N as there is the same error. Pin 56 and pin 51
We are working on it.
Solved by this thread: Pin 26 and Pin 11 are the same PWM13.1 - TinyCLR - GHI Electronics’ Forums
