Hi Support,
I am attempting to build the mainboard solution for the Hydra
@ Main\Mainboards\GHIElectronics\FEZ Hydra\Software\NETMF 4.1 Firmware\Solutions\FEZ_Hydra
\dotnetmf.proj
— > I am getting 5 errors when compiling (see error below)
It appears I am missing projects that were not included in the netmf 4.1 or the Gadgeteer source.
Any help would be appreciated
I followed these directions:
- Install NETMF 4.1 PK
- install ARM network pack 4.1
- Install Crypto pack 4.1
- Copy everything from this folder to C:\MicroFrameworkPK_v4_1 overwriting any existing files
- Build FEZ Hydra solution. (I used MSBUILD.EXE /t:build /p:flavor=release;memory=flash) in the project directory
I have installed the GCC lite version which was recommended in the porting kit walkthrough.
http://www.codesourcery.com/sgpp/lite/arm/portal/release316
And source for Hydra board is version 16371
gadgeteer-16371.zip
ERRORS:
“D:\MicroFrameworkPK_v4_1\Solutions\FEZ_Hydra\dotnetmf.proj” (build target) (1)
(BuildDependencies target) →
D:\MicroFrameworkPK_v4_1\tools\targets\Microsoft.SPOT.System.Targets(314,5):
error MSB3202: The project file “NativeSample\NativeSample.proj” was not found.
[D:\MicroFrameworkPK_v4_1\Solutions\FEZ_Hydra\dotnetmf.proj]
error MSB3202: The project file “PortBooter\portBooter.proj” was not found. [D:
error MSB3202: The project file “PortBooter\portBooterloader.proj” was not foun
d. [D:\MicroFrameworkPK_v4_1\Solutions\FEZ_Hydra\dotnetmf.proj]
error MSB3202: The project file “TinyBooter\TinyBooterDecompressor.proj” was no
t found. [D:\MicroFrameworkPK_v4_1\Solutions\FEZ_Hydra\dotnetmf.proj]
“D:\MicroFrameworkPK_v4_1\Solutions\FEZ_Hydra\TinyCLR\TinyCLR.proj” (Build targ
et) (76) →
(BuildAXF target) →
D:\MicroFrameworkPK_v4_1\tools\targets\Microsoft.SPOT.System.GCC.targets(306,
5): error MSB3073: The command ““c:\gcc\bin\arm-none-eabi-ld.exe” -static --g
c-sections --no-warn-mismatch --library-path=D:\MicroFrameworkPK_v4_1\BuildOutp
ut\ARM\GCC4.2\le\FLASH\release\FEZ_Hydra\lib --library-path=D:\MicroFrameworkPK
v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib -u ARM_Vectors -u star
t --Map D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\FLASH\release\FEZ_Hy
dra\bin\tinyclr.map --output=D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le
\FLASH\release\FEZ_Hydra\bin\tinyclr.axf --script=D:\MicroFrameworkPK_v4_1\Buil
dOutput\ARM\GCC4.2\le\FLASH\release\FEZ_Hydra\bin\tinyclr_scatterfile.ldf D:\Mi
croFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\FLASH\release\FEZ_Hydra\obj\Solut
ions\FEZ_Hydra\TinyCLR\tinyclr_dat.obj D:\MicroFrameworkPK_v4_1\BuildOutput\ARM
\GCC4.2\le\FLASH\release\FEZ_Hydra\obj\Solutions\FEZ_Hydra\TinyCLR\allocator.ob
j D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\FLASH\release\FEZ_Hydra\ob
j\Solutions\FEZ_Hydra\TinyCLR\tinyclr.obj -( D:\MicroFrameworkPK_v4_1\BuildOutp
ut\ARM\GCC4.2\le\ANY_MEDIA\release\lib\Core.lib D:\MicroFrameworkPK_v4_1\BuildO
utput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\Hardware.lib D:\MicroFrameworkPK_v4_1
\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\InterruptHandler.lib D:\MicroF
rameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\HeapPersistence
.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\I
2C.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib
\IOPort.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\releas
e\lib\Serialization.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY
MEDIA\release\lib\Stream.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le
\ANY_MEDIA\release\lib\Debugger.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GC
C4.2\le\ANY_MEDIA\release\lib\Debugger_full.lib D:\MicroFrameworkPK_v4_1\BuildO
utput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\Diagnostics.lib D:\MicroFrameworkPK_v
4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\Graphics_Bmp.lib D:\MicroFr
ameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\Graphics.lib D:
MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\Graphics
Gif.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\li
b\Graphics_Jpeg.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDI
A\release\lib\CorLib.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY
MEDIA\release\lib\SPOT.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le
ANY_MEDIA\release\lib\SPOT_Crypto.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM
GCC4.2\le\ANY_MEDIA\release\lib\SPOT_Serialization.lib D:\MicroFrameworkPK_v4_1
\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\SPOT_Graphics.lib D:\MicroFram
eworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\SPOT_Hardware.lib
D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\SPOT_T
ouch.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\l
ib\SPOT_Hardware_SerialPort.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2
\le\ANY_MEDIA\release\lib\SPOT_Hardware_Usb.lib D:\MicroFrameworkPK_v4_1\BuildO
utput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\Xml.lib D:\MicroFrameworkPK_v4_1\Buil
dOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\System_Xml.lib D:\MicroFrameworkPK
v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\SPOT_IO.lib D:\MicroFramew
orkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\SPOT_Net.lib D:\Micr
oFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\Messaging.lib
D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release\lib\CLRSt
artup.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\release
lib\CRC.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_MEDIA\releas
e\lib\WireProtocol.lib D:\MicroFrameworkPK_v4_1\BuildOutput\ARM\GCC4.2\le\ANY_M
EDIA\release\lib\SPOT_Messaging_stub.lib D:\MicroFrameworkPK_v4_1\BuildOutput\A
RM\GCC4.2\le\ANY_MEDIA\release\lib\RPC_stub.lib D:\MicroFrameworkPK_v4_1\BuildO
utput\ARM\GCC4.2\le\FLASH\release\FEZ_Hydra\lib\tmp_tinyclr.lib D:\MicroFramewo
rkPK_v4_1\BuildOutput\ARM\GCC4.2\le\FLASH\release\FEZ_Hydra\lib\InteropAssembli
esTable.lib -) -( “c:\gcc\arm-none-eabi\lib\libm.a” “c:\gcc\arm-none-eabi\lib
\libc.a” “c:\gcc\lib\gcc\arm-none-eabi\4.2.1\libgcc.a” -) -( -)” exited with
code 1. [D:\MicroFrameworkPK_v4_1\Solutions\FEZ_Hydra\TinyCLR\TinyCLR.proj]
32 Warning(s)
5 Error(s)
