I have a question. In full .NET, this code prints “Two”
class Program
public enum Words
One,
Two
static void Main(string[] args)
Words word = Words.Two;
Console.WriteLine(word.ToString());
In NETMF, this similar code prints “1”
public enum Words
One,
Two
Debug.Print(word.ToString());
How do I make NETMF print “Two” instead of “1”?
The above are made up examples, in my real scenario, there are more enum values and I’d rather not do a giant switch case statement to translate the enum integer values back to human readable words. Thanks!
I ran into the same issue. Unfortunately, there currently doesn’t seem to be a way to get the string representation of an enum value. I think you’re stuck using a switch statement for now ???
public enum Words
One,
Two
string[] WordsStr = new string[2] {"One","Two"};
public void Test()
Debug.Print(WordsStr[(int)word]);
Instead of creating your array by hand, you can do:
public string[] GetStringArray(Type type)
//use Reflection to get the fields in our enum
FieldInfo[] info = type.GetFields();
//new ArrayList to hold the values (will convert later)
ArrayList fields = new ArrayList();
//loop through all the fields
foreach (FieldInfo fInfo in info)
//add each to our ArrayList
fields.Add(fInfo.Name);
//now we convert to string array and return
return (string[]) fields . ToArray ( typeof ( string ) );
PS I don’t know why that link is appearing after ToArray, tried to add spaces but it’s still there
public enum WebSocketState
Initialized = 0, // initial state
Connecting,
Connected,
Disconnecting,
Disconnected
public static class WebSocketStateExtensions
public static string Name(this WebSocketState webSocketState)
string text = "";
switch (webSocketState)
case WebSocketState.Initialized:
text = "Initialized";
break;
case WebSocketState.Connecting:
text = "Connecting";
break;
case WebSocketState.Connected:
text = "Connected";
break;
case WebSocketState.Disconnecting:
text = "Disconnecting";
break;
case WebSocketState.Disconnected:
text = "Disconnected";
break;
return text;
