ReSharper will pull the full source out of the .pdb files. Here’s the entire Enum class. Enjoy!
// Copyright (c) Microsoft Corporation. All rights reserved.
using System.Reflection;
using System.Text;
using System.Collections;
using System.Globalization;
using System.Runtime.CompilerServices;
using System.Runtime.InteropServices;
using System.Security;
using System.Runtime.Versioning;
using System.Diagnostics.Contracts;
namespace System
[Serializable]
[System.Runtime.InteropServices.ComVisible(true)]
public abstract class Enum : ValueType, IComparable, IFormattable, IConvertible
#region Private Static Data Members
private static readonly char [] enumSeperatorCharArray = new char [] {','};
private const String enumSeperator = ", ";
private static Hashtable fieldInfoHash = Hashtable.Synchronized(new Hashtable());
private const int maxHashElements = 100; // to trim the working set
#endregion
#region Private Static Methods
[System.Security.SecuritySafeCritical] // auto-generated
private static HashEntry GetHashEntry(RuntimeType enumType)
Contract.Requires(enumType != null);
Contract.Ensures(Contract.Result<HashEntry>() != null);
HashEntry hashEntry = (HashEntry)fieldInfoHash[enumType];
if (hashEntry == null)
// To reduce the workingset we clear the hashtable when a threshold number of elements are inserted.
if (fieldInfoHash.Count > maxHashElements)
fieldInfoHash.Clear();
ulong[] values = null;
String[] names = null;
GetEnumValues(enumType.GetTypeHandleInternal(),
JitHelpers.GetObjectHandleOnStack(ref values), JitHelpers.GetObjectHandleOnStack(ref names));
hashEntry = new HashEntry(names, values);
fieldInfoHash[enumType] = hashEntry;
return hashEntry;
private static String InternalFormattedHexString(Object value)
TypeCode typeCode = Convert.GetTypeCode(value);
switch (typeCode)
case TypeCode.SByte :
Byte result = (byte)(sbyte)value;
return result.ToString("X2", null);
case TypeCode.Byte :
Byte result = (byte)value;
case TypeCode.Int16 :
UInt16 result = (UInt16)(Int16)value;
return result.ToString("X4", null);
case TypeCode.UInt16 :
UInt16 result = (UInt16)value;
case TypeCode.UInt32 :
UInt32 result = (UInt32)value;
return result.ToString("X8", null);
case TypeCode.Int32 :
UInt32 result = (UInt32)(int)value;
case TypeCode.UInt64 :
UInt64 result = (UInt64)value;
return result.ToString("X16", null);
case TypeCode.Int64 :
UInt64 result = (UInt64)(Int64)value;
// All unsigned types will be directly cast
default :
Contract.Assert(false, "Invalid Object type in Format");
throw new InvalidOperationException(Environment.GetResourceString("InvalidOperation_UnknownEnumType"));
private static String InternalFormat(RuntimeType eT, Object value)
Contract.Requires(eT != null);
Contract.Requires(value != null);
if (!eT.IsDefined(typeof(System.FlagsAttribute), false)) // Not marked with Flags attribute
// Try to see if its one of the enum values, then we return a String back else the value
String retval = GetName(eT, value);
if (retval == null)
return value.ToString();
return retval;
else // These are flags OR'ed together (We treat everything as unsigned types)
return InternalFlagsFormat(eT, value);
private static String InternalFlagsFormat(RuntimeType eT, Object value)
ulong result = ToUInt64(value);
HashEntry hashEntry = GetHashEntry(eT);
// These values are sorted by value. Don't change this
String[] names = hashEntry.names;
ulong[] values = hashEntry.values;
Contract.Assert(names.Length == values.Length);
int index = values.Length - 1;
StringBuilder retval = new StringBuilder();
bool firstTime = true;
ulong saveResult = result;
// We will not optimize this code further to keep it maintainable. There are some boundary checks that can be applied
// to minimize the comparsions required. This code works the same for the best/worst case. In general the number of
// items in an enum are sufficiently small and not worth the optimization.
while (index >= 0)
if ((index == 0) && (values[index] == 0))
break;
if ((result & values[index]) == values[index])
result -= values[index];
if (!firstTime)
retval.Insert(0, enumSeperator);
retval.Insert(0, names[index]);
firstTime = false;
index--;
// We were unable to represent this number as a bitwise or of valid flags
if (result != 0)
// For the case when we have zero
if (saveResult==0)
if (values.Length > 0 && values[0] == 0)
return names[0]; // Zero was one of the enum values.
return "0";
return retval.ToString(); // Return the string representation
internal static ulong ToUInt64(Object value)
// Helper function to silently convert the value to UInt64 from the other base types for enum without throwing an exception.
// This is need since the Convert functions do overflow checks.
ulong result;
switch(typeCode)
case TypeCode.SByte:
case TypeCode.Int16:
case TypeCode.Int32:
case TypeCode.Int64:
result = (UInt64)Convert.ToInt64(value, CultureInfo.InvariantCulture);
break;
case TypeCode.Byte:
case TypeCode.UInt16:
case TypeCode.UInt32:
case TypeCode.UInt64:
result = Convert.ToUInt64(value, CultureInfo.InvariantCulture);
break;
default:
Contract.Assert(false, "Invalid Object type in ToUInt64");
return result;
[System.Security.SecurityCritical] // auto-generated
[ResourceExposure(ResourceScope.None)]
[MethodImplAttribute(MethodImplOptions.InternalCall)]
private static extern int InternalCompareTo(Object o1, Object o2);
internal static extern RuntimeType InternalGetUnderlyingType(RuntimeType enumType);
[DllImport(JitHelpers.QCall, CharSet = CharSet.Unicode)]
[SuppressUnmanagedCodeSecurity]
private static extern void GetEnumValues(RuntimeTypeHandle enumType, ObjectHandleOnStack values, ObjectHandleOnStack names);
private static extern Object InternalBoxEnum(RuntimeType enumType, long value);
#endregion
#region Public Static Methods
private enum ParseFailureKind
None = 0,
Argument = 1,
ArgumentNull = 2,
ArgumentWithParameter = 3,
UnhandledException = 4
// This will store the result of the parsing.
private struct EnumResult
internal object parsedEnum;
internal bool canThrow;
internal ParseFailureKind m_failure;
internal string m_failureMessageID;
internal string m_failureParameter;
internal object m_failureMessageFormatArgument;
internal Exception m_innerException;
internal void Init(bool canMethodThrow)
parsedEnum = 0;
canThrow = canMethodThrow;
internal void SetFailure(Exception unhandledException)
m_failure = ParseFailureKind.UnhandledException;
m_innerException = unhandledException;
internal void SetFailure(ParseFailureKind failure, string failureParameter)
m_failure = failure;
m_failureParameter = failureParameter;
if (canThrow)
throw GetEnumParseException();
internal void SetFailure(ParseFailureKind failure, string failureMessageID, object failureMessageFormatArgument)
m_failureMessageID = failureMessageID;
m_failureMessageFormatArgument = failureMessageFormatArgument;
if (canThrow)
internal Exception GetEnumParseException()
switch (m_failure)
case ParseFailureKind.Argument:
return new ArgumentException(Environment.GetResourceString(m_failureMessageID));
case ParseFailureKind.ArgumentNull:
return new ArgumentNullException(m_failureParameter);
case ParseFailureKind.ArgumentWithParameter:
return new ArgumentException(Environment.GetResourceString(m_failureMessageID, m_failureMessageFormatArgument));
case ParseFailureKind.UnhandledException:
return m_innerException;
default:
Contract.Assert(false, "Unknown EnumParseFailure: " + m_failure);
return new ArgumentException(Environment.GetResourceString("Arg_EnumValueNotFound"));
public static bool TryParse<TEnum>(String value, out TEnum result) where TEnum : struct
return TryParse(value, false, out result);
public static bool TryParse<TEnum>(String value, bool ignoreCase, out TEnum result) where TEnum : struct
result = default(TEnum);
EnumResult parseResult = new EnumResult();
parseResult.Init(false);
bool retValue;
if (retValue = TryParseEnum(typeof(TEnum), value, ignoreCase, ref parseResult))
result = (TEnum)parseResult.parsedEnum;
return retValue;
public static Object Parse(Type enumType, String value)
return Parse(enumType, value, false);
public static Object Parse(Type enumType, String value, bool ignoreCase)
parseResult.Init(true);
if (TryParseEnum(enumType, value, ignoreCase, ref parseResult))
return parseResult.parsedEnum;
throw parseResult.GetEnumParseException();
private static bool TryParseEnum(Type enumType, String value, bool ignoreCase, ref EnumResult parseResult)
if (enumType == null)
throw new ArgumentNullException("enumType");
Contract.EndContractBlock();
RuntimeType rtType = enumType as RuntimeType;
if (rtType == null)
throw new ArgumentException(Environment.GetResourceString("Arg_MustBeType"), "enumType");
if (!enumType.IsEnum)
throw new ArgumentException(Environment.GetResourceString("Arg_MustBeEnum"), "enumType");
if (value == null) {
parseResult.SetFailure(ParseFailureKind.ArgumentNull, "value");
return false;
value = value.Trim();
if (value.Length == 0) {
parseResult.SetFailure(ParseFailureKind.Argument, "Arg_MustContainEnumInfo", null);
return false;
// We have 2 code paths here. One if they are values else if they are Strings.
// values will have the first character as as number or a sign.
ulong result = 0;
if (Char.IsDigit(value[0]) || value[0] == '-' || value[0] == '+')
Type underlyingType = GetUnderlyingType(enumType);
Object temp;
try
temp = Convert.ChangeType(value, underlyingType, CultureInfo.InvariantCulture);
parseResult.parsedEnum = ToObject(enumType, temp);
return true;
catch (FormatException)
{ // We need to Parse this as a String instead. There are cases
// when you tlbimp enums that can have values of the form "3D".
// Don't fix this code.
catch (Exception ex)
if (parseResult.canThrow)
throw;
parseResult.SetFailure(ex);
return false;
String[] values = value.Split(enumSeperatorCharArray);
// Find the field.Lets assume that these are always static classes because the class is
// an enum.
HashEntry hashEntry = GetHashEntry(rtType);
for (int i = 0; i < values.Length; i++)
values[i] = values[i].Trim(); // We need to remove whitespace characters
bool success = false;
for (int j = 0; j < names.Length; j++)
if (ignoreCase)
if (String.Compare(names[j], values[i], StringComparison.OrdinalIgnoreCase) != 0)
continue;
if (!names[j].Equals(values[i]))
continue;
ulong item = hashEntry.values[j];
result |= item;
success = true;
break;
if (!success)
// Not found, throw an argument exception.
parseResult.SetFailure(ParseFailureKind.ArgumentWithParameter, "Arg_EnumValueNotFound", value);
return false;
try
parseResult.parsedEnum = ToObject(enumType, result);
return true;
throw;
return false;
public static Type GetUnderlyingType(Type enumType)
return enumType.GetEnumUnderlyingType();
public static Array GetValues(Type enumType)
return enumType.GetEnumValues();
internal static ulong[] InternalGetValues(RuntimeType enumType)
// Get all of the values
return GetHashEntry(enumType).values;
public static String GetName(Type enumType, Object value)
return enumType.GetEnumName(value);
public static String[] GetNames(Type enumType)
return enumType.GetEnumNames();
internal static String[] InternalGetNames(RuntimeType enumType)
return GetHashEntry(enumType).names;
public static Object ToObject(Type enumType, Object value)
if (value == null)
throw new ArgumentNullException("value");
// Delegate rest of error checking to the other functions
switch (typeCode)
return ToObject(enumType, (int)value);
return ToObject(enumType, (sbyte)value);
return ToObject(enumType, (short)value);
return ToObject(enumType, (long)value);
return ToObject(enumType, (uint)value);
return ToObject(enumType, (byte)value);
return ToObject(enumType, (ushort)value);
return ToObject(enumType, (ulong)value);
default :
throw new ArgumentException(Environment.GetResourceString("Arg_MustBeEnumBaseTypeOrEnum"), "value");
[Pure]
public static bool IsDefined(Type enumType, Object value)
return enumType.IsEnumDefined(value);
public static String Format(Type enumType, Object value, String format)
if (value == null)
if (format == null)
throw new ArgumentNullException("format");
if (rtType == null)
// Check if both of them are of the same type
Type valueType = value.GetType();
// If the value is an Enum then we need to extract the underlying value from it
if (valueType.IsEnum) {
Type valueUnderlyingType = GetUnderlyingType(valueType);
if (!valueType.IsEquivalentTo(enumType))
throw new ArgumentException(Environment.GetResourceString("Arg_EnumAndObjectMustBeSameType", valueType.ToString(), enumType.ToString()));
valueType = valueUnderlyingType;
value = ((Enum)value).GetValue();
// The value must be of the same type as the Underlying type of the Enum
else if (valueType != underlyingType) {
throw new ArgumentException(Environment.GetResourceString("Arg_EnumFormatUnderlyingTypeAndObjectMustBeSameType", valueType.ToString(), underlyingType.ToString()));
if( format.Length != 1) {
// all acceptable format string are of length 1
throw new FormatException(Environment.GetResourceString("Format_InvalidEnumFormatSpecification"));
char formatCh = format[0];
if (formatCh == 'D' || formatCh == 'd') {
if (formatCh == 'X' || formatCh == 'x') {
// Retrieve the value from the field.
return InternalFormattedHexString(value);
if (formatCh == 'G' || formatCh == 'g') {
return InternalFormat(rtType, value);
if (formatCh == 'F' || formatCh == 'f') {
return InternalFlagsFormat(rtType, value);
#endregion
#region Definitions
private class HashEntry
// Each entry contains a list of sorted pair of enum field names and values, sorted by values
public HashEntry(String [] names, ulong [] values)
this.names = names;
this.values = values;
public String[] names;
public ulong [] values;
#endregion
#region Private Methods
internal Object GetValue()
return InternalGetValue();
private extern Object InternalGetValue();
#endregion
#region Object Overrides
public extern override bool Equals(Object obj);
public override int GetHashCode()
return GetValue().GetHashCode();
public override String ToString()
// Returns the value in a human readable format. For PASCAL style enums who's value maps directly the name of the field is returned.
// For PASCAL style enums who's values do not map directly the decimal value of the field is returned.
// For BitFlags (indicated by the Flags custom attribute): If for each bit that is set in the value there is a corresponding constant
//(a pure power of 2), then the OR string (ie "Red | Yellow") is returned. Otherwise, if the value is zero or if you can't create a string that consists of
// pure powers of 2 OR-ed together, you return a hex value
return Enum.InternalFormat((RuntimeType)GetType(), GetValue());
#endregion
#region IFormattable
[Obsolete("The provider argument is not used. Please use ToString(String).")]
public String ToString(String format, IFormatProvider provider)
return ToString(format);
#endregion
#region IComparable
public int CompareTo(Object target)
const int retIncompatibleMethodTables = 2; // indicates that the method tables did not match
const int retInvalidEnumType = 3; // indicates that the enum was of an unknown/unsupported unerlying type
if (this == null)
throw new NullReferenceException();
int ret = InternalCompareTo(this, target);
if (ret < retIncompatibleMethodTables)
// -1, 0 and 1 are the normal return codes
return ret;
else if (ret == retIncompatibleMethodTables)
Type thisType = this.GetType();
Type targetType = target.GetType();
targetType.ToString(), thisType.ToString()));
// assert valid return code (3)
Contract.Assert(ret == retInvalidEnumType, "Enum.InternalCompareTo return code was invalid");
#endregion
#region Public Methods
public String ToString(String format) {
if (format == null || format.Length == 0)
format = "G";
if (String.Compare(format, "G", StringComparison.OrdinalIgnoreCase) == 0)
return ToString();
if (String.Compare(format, "D", StringComparison.OrdinalIgnoreCase) == 0)
return GetValue().ToString();
if (String.Compare(format, "X", StringComparison.OrdinalIgnoreCase) == 0)
return InternalFormattedHexString(GetValue());
if (String.Compare(format, "F", StringComparison.OrdinalIgnoreCase) == 0)
return InternalFlagsFormat((RuntimeType)GetType(), GetValue());
[Obsolete("The provider argument is not used. Please use ToString().")]
public String ToString(IFormatProvider provider)
return ToString();
public Boolean HasFlag(Enum flag) {
if (!this.GetType().IsEquivalentTo(flag.GetType())) {
throw new ArgumentException(Environment.GetResourceString("Argument_EnumTypeDoesNotMatch", flag.GetType(), this.GetType()));
ulong uFlag = ToUInt64(flag.GetValue());
ulong uThis = ToUInt64(GetValue());
return ((uThis & uFlag) == uFlag);
#endregion
#region IConvertable
public TypeCode GetTypeCode()
Type enumType = this.GetType();
if (underlyingType == typeof(Int32))
return TypeCode.Int32;
if (underlyingType == typeof(sbyte))
return TypeCode.SByte;
if (underlyingType == typeof(Int16))
return TypeCode.Int16;
if (underlyingType == typeof(Int64))
return TypeCode.Int64;
if (underlyingType == typeof(UInt32))
return TypeCode.UInt32;
if (underlyingType == typeof(byte))
return TypeCode.Byte;
if (underlyingType == typeof(UInt16))
return TypeCode.UInt16;
if (underlyingType == typeof(UInt64))
return TypeCode.UInt64;
Contract.Assert(false, "Unknown underlying type.");
/// <internalonly/>
bool IConvertible.ToBoolean(IFormatProvider provider)
return Convert.ToBoolean(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
char IConvertible.ToChar(IFormatProvider provider)
return Convert.ToChar(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
sbyte IConvertible.ToSByte(IFormatProvider provider)
return Convert.ToSByte(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
byte IConvertible.ToByte(IFormatProvider provider)
return Convert.ToByte(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
short IConvertible.ToInt16(IFormatProvider provider)
return Convert.ToInt16(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
ushort IConvertible.ToUInt16(IFormatProvider provider)
return Convert.ToUInt16(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
int IConvertible.ToInt32(IFormatProvider provider)
return Convert.ToInt32(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
uint IConvertible.ToUInt32(IFormatProvider provider)
return Convert.ToUInt32(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
long IConvertible.ToInt64(IFormatProvider provider)
return Convert.ToInt64(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
ulong IConvertible.ToUInt64(IFormatProvider provider)
return Convert.ToUInt64(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
float IConvertible.ToSingle(IFormatProvider provider)
return Convert.ToSingle(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
double IConvertible.ToDouble(IFormatProvider provider)
return Convert.ToDouble(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
Decimal IConvertible.ToDecimal(IFormatProvider provider)
return Convert.ToDecimal(GetValue(), CultureInfo.CurrentCulture);
/// <internalonly/>
DateTime IConvertible.ToDateTime(IFormatProvider provider)
throw new InvalidCastException(Environment.GetResourceString("InvalidCast_FromTo", "Enum", "DateTime"));
/// <internalonly/>
Object IConvertible.ToType(Type type, IFormatProvider provider)
return Convert.DefaultToType((IConvertible)this, type, provider);
#endregion
#region ToObject
[CLSCompliant(false)]
public static Object ToObject(Type enumType, sbyte value)
if (rtType == null)
return InternalBoxEnum(rtType, value);
public static Object ToObject(Type enumType, short value)
if (rtType == null)
public static Object ToObject(Type enumType, int value)
if (rtType == null)
public static Object ToObject(Type enumType, byte value)
if (rtType == null)
public static Object ToObject(Type enumType, ushort value)
if (rtType == null)
public static Object ToObject(Type enumType, uint value)
if (rtType == null)
public static Object ToObject(Type enumType, long value)
if (rtType == null)
public static Object ToObject(Type enumType, ulong value)
if (rtType == null)
return InternalBoxEnum(rtType, unchecked((long)value));
#endregion
// File provided for Reference Use Only by Microsoft Corporation (c) 2007.
