This is a VSCode issue only.
I’ve experienced this, and maybe you have too, but if I use Ctrl-Shift-B to build, and then I try to use F5, then the ‘publish’ command fails when it tries to publish the x64 bits instead of re-building for Release/Any CPU.
The fix is to edit tasks.json and change the “AppTemplPublish” task to read as follows:
"label": "AppTemplPublish",
"command": "dotnet",
"type": "shell",
"dependsOn": "build",
"args": [
"publish",
"-p:Platform='Any CPU'",
"-r","linux-arm",
"-o","bin\\linux-arm\\publish",
"--self-contained","false"
Note that the way that I have reworked this item also causes this to work on non-Windows systems. There are other tweaks required for AppTemplDeploy and AppTemplStop to make them work on non-Windows systems, but that’s not the point of this post. The above is an issue on Windows systems.
@Gus_Issa/@Dat_Tran : Where do you want issues submitted for the VSCode extension and template?
