Somewhat newbe here, I’m not terribly experienced in VS, so bear that in mind. Clean install of VS2022 Community edition. Installed endpoint debugger. Tried to created a new project. Clicked on debug - options - endpoint debugger. When I select the device connected (192.168.82.something), it can’t connect to the device, gives me an error and won’t ‘make’ the connection.
Tried copying over the IPcamera example last night and running that - it seemed to work OK and communicated with the device, and it errored out when it went looking for a wifi bit that wasn’t there.
This morning started up VS, using the ipcamera example, clicked debug - options - endpoint debugger, and VS crashes when trying to execute that commend. Uninstalled the endpoint extension, then went back and re-installed it - it still crashes when I select debug - options - endpoint debugger. VS then helpfully suggests I disable the endpoint extension… well thats not really very helpful, is it lol!
And just so I know, when we create a new project, we won’t see something like “new Endpoint C# Project” we just select a generic C# windows form project, right?
Thanks folks!
John
