How are you celebrating the Holidays? We’re celebrating by using .NET on hardware. Check out this video.
You won’t be playing with us this year, but have a happy and safe holiday. We’ll let you join the party in 2024.
using System.Device.Gpio.Drivers;
using SkiaSharp;
using System.Runtime.InteropServices;
using GHIElectronics.Endpoint.Core;
using GHIElectronics.Endpoint.Devices.Display;
using EndpointDisplayTest.Properties;
var port = EPM815.Gpio.Pin.PD14 /16;
var pin = EPM815.Gpio.Pin.PD14 % 16;
var gpioController = new GpioController(PinNumberingScheme.Logical, new LibGpiodDriver(port));
gpioController.OpenPin(pin, PinMode.Output);
gpioController.Write(pin, PinValue.High);
var screenWidth = 480;
var screenHeight = 272;
var imageWidth = 275;
var imageHeight = 183;
SKBitmap bitmap = new SKBitmap(screenWidth, screenHeight, SKImageInfo.PlatformColorType, SKAlphaType.Premul);
bitmap.Erase(SKColors.Transparent);
var configuration = new FBDisplay.ParallelConfiguration()
Clock = 10000,
Width = 480,
Hsync_start = 480 + 2,
Hsync_end = 480 + 2 + 41,
Htotal = 480 + 2 + 41 + 2,
Height = 272,
Vsync_start = 272 + 2,
Vsync_end = 272 + 2 + 10,
Vtotal = 272 + 2 + 10 + 2,
var fbDisplay = new FBDisplay(configuration);
var displayController = new DisplayController(fbDisplay);
var img = Resources.endpointFireworks;
SKBitmap[] sk_imgs = null;
var framecnt = 0;
var x1 = -300;
var x2 = 480;
var x3 = -300;
while (true){
using (var stream = new MemoryStream(img)){
using (var canvas = new SKCanvas(bitmap)){
using (SKManagedStream skStream = new SKManagedStream(stream)){
using (SKCodec codec = SKCodec.Create(skStream)) {
//Get frame count and allocate bitmaps
int frameCount = codec.FrameCount;
var bitmaps = new SKBitmap[frameCount];
var durations = new int[frameCount];
var accumulatedDurations = new int[frameCount];
if (sk_imgs == null){
sk_imgs = new SKBitmap[frameCount];
//Loop through the frames
for (int frame = 0; frame < frameCount; frame++){
durations[frame] = codec.FrameInfo[frame].Duration;
// Create a full color bitmap for each frame
if (sk_imgs[frame] == null){
var imageInfo = new SKImageInfo(codec.Info.Width,codec.Info.Height, SKImageInfo.PlatformColorType, SKAlphaType.Unpremul);
bitmaps[frame] = new SKBitmap(imageInfo);
//Get the address of the pixels in that bitmap
IntPtr pointer = bitmaps[frame].GetPixels();
//Create an SKCodecOptions value to specify the frame
SKCodecOptions codecOptions = new SKCodecOptions(frame);
//Copy pixels from the frame into the bitmap
codec.GetPixels(imageInfo, pointer, codecOptions);
var pixelArray = bitmaps[frame].Bytes;
//pin the managed array so that the GC doesn't move it
var gcHandle = GCHandle.Alloc(pixelArray, GCHandleType.Pinned);
var info = new SKImageInfo(codec.Info.Width, codec.Info.Height);
var sk_img = SKBitmap.Decode(img, info);
//install the pixels with the color type of the pixel data
_ = sk_img.InstallPixels(
info: imageInfo,
pixels: gcHandle.AddrOfPinnedObject(),
rowBytes: imageInfo.RowBytes,
ctable: null,
releaseProc: delegate { gcHandle.Free(); },
context: null);
sk_imgs[frame] = sk_img;
framecnt++;
if (framecnt > frameCount){
//Create Black Screen
canvas.DrawColor(SKColors.White);
canvas.Clear(SKColors.White);
canvas.DrawBitmap(sk_imgs[frame], (screenWidth - codec.Info.Width) / 2, (screenHeight - codec.Info.Height) / 2); // where it is on the screen
using (SKPaint text = new SKPaint())
text.Color = SKColors.Yellow;
text.IsAntialias = true;
text.StrokeWidth = 2;
text.Style = SKPaintStyle.Stroke;
//SKFont Text -
SKFont font = new SKFont();
font.Size = 45;
font.ScaleX = 2;
SKTextBlob textBlob = SKTextBlob.Create("Happy", font);
canvas.DrawText(textBlob, x1, 60, text);
if (x1 < 100)
x1 += 20;
text.Color = SKColors.White;
text.StrokeWidth = 4;
text.Style = SKPaintStyle.StrokeAndFill;
//SKFont Text -
font.Size = 45;
font.ScaleX = 2;
SKTextBlob textBlob = SKTextBlob.Create(".NET 8", font);
canvas.DrawText(textBlob, x2, 160, text);
if (x2 > 85)
x2 -= 20;
//SKFont Text -
font.Size = 45;
font.ScaleX = 2;
SKTextBlob textBlob = SKTextBlob.Create("2024", font);
canvas.DrawText(textBlob, x3, 250 , text);
if (x3 < 130)
x3 += 22;
var data = bitmap.Copy(SKColorType.Rgb565).Bytes;
displayController.Flush(data);
Thread.Sleep(durations[frame]);
else{
canvas.DrawColor(SKColors.Black);
canvas.Clear(SKColors.Black);
var logo = Resources.logo;
var info = new SKImageInfo(imageWidth, imageHeight);
var sk_img = SKBitmap.Decode(logo, info);
canvas.DrawBitmap(sk_img, (screenWidth - imageWidth) / 2, (screenHeight - imageHeight)/2);
Yes, but when will you be ready?
whoaaa… happy new year
