What is the difference between these two calls?
Where do you see them?
I’d say it’s the same. The “J60” is often cut off wo make it short.
First, I apologize for my poorly asked question. I’ve attached an image to show what I mean. I guess there are some obvious differences but more than the differences why would you use one instead of the other?
I got you now.
the ENC28J60 is the “core NETMF driver” interface, if you like to call it that way.
the ENC28 is a Gadgeteer module driver.
Gadgeteer is a on top layer over NETMF.
But it is often recommended to avoid using Gadgeteer networking modules if possible, and use the pure NETMF ones directly for stability reasons.
But actually I nerer used the Gadgeteer ones so far, so I can’t confirm this first hand.
