We need to remove the RJ45 connector box from the ENC28 module and solder pin headers in its place, so we can connect two external through the wall LEDs for Ethernet activity and an external through the wall circular RJ45 connector. Can we purchase ENC28 modules with the RJ45 connector box not soldered to the board?
@ dspacek - If you need a special run of a module, please contact us directly with what you would require. However, there will be a minimum order requirement to get a custom run.
Optionally you can make the boards yourself.
It’s open HW.
Shouldn’t be to hard to make your own board having the schematics.
