when I start the Hydra without the ENC28 connected to Socket 3 it seems that the device is locked:
The USB is not detected as Gadgeteer module and I can’t ping it with MFDeploy.
Therefore I think that I flashed the Ethernet firmware as you could see in my first message.
C:\Program Files\GHI Electronics\GHI OSH NETMF v4.1 SDK\FEZ Hydra\Firmware\FEZ H
ydra TinyBooter Updater>ping 192.168.57.157
Ping wird ausgeführt für 192.168.57.157 mit 32 Bytes Daten:
Antwort von 192.168.57.157: Bytes=32 Zeit=2ms TTL=255
Antwort von 192.168.57.157: Bytes=32 Zeit=1ms TTL=255
Ping-Statistik für 192.168.57.157:
Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0 (0% Verlust),
Ca. Zeitangaben in Millisek.:
Minimum = 1ms, Maximum = 2ms, Mittelwert = 1ms
I used both MFDeploy and software to set the IP address.
What have I changed meanwhile:
Once again I did the firmware update with one exception: When I flashed the TinyCLR ethernet firmware I had the ENC28 module connected to the Socket 3.
After flashing I got a lot of messages, which I didn’t see when I flashed without the ENC module connected:
Pinging... TinyBooter
Bootloader build info: Copyright (C) GHI Electronics, LLC
Chk signature
Signature PASS
Chk signature
Signature PASS
*** nXIP Program found at 0x00084000 <-- here it stopped without the ENC connected, but now continued
Created EE.
Started Hardware.
Found debugger!
Create TS.
Loading start at 2018cc1c, end 201b43a8
Attaching file.
Resources Data = 1184 bytes
I’ll continue tomorrow as it is almost 9 p.m. here.
BTW: Power is correct with the USB client module and external power supply.
