I’m currently playing with a max232 on the extender.
The serial port works fine and i’m able to communicate with other equipements, but… as soon as I open the com port in a gadgeteer application, I get the following message in VS : [italic]Updating display configuration. DEVICE WILL NOW REBOOT. Visual Studio might lose connection, and debugging might need to be manually restarted[/italic], and the screen is disabled. I had to deploy an empty gadgeteer app to restore it.
When I do the same in an app based on the NetMF console application, the screen keeps working.
Here is the code I used in the gadgeteer app :
using System.IO.Ports;
using System.Text;
namespace TestSerialPort
public partial class Program
// Fez Spider sockets :
// Com1 : 11
// Com2 : 4
// Com3 : 8
// Com4 : 9
private SerialPort comPort;
comPort = new SerialPort("COM2", 9600, Parity.None, 8, StopBits.One);
comPort.Handshake = Handshake.RequestToSend;
comPort.DataReceived += ComPortDataReceived;
comPort.ErrorReceived += ComPortErrorReceived;
comPort.ReadTimeout = 200;
try
Debug.Print("Opening " + comPort.PortName);
comPort.Open();
Debug.Print("open");
catch (Exception ex)
Debug.Print("Unable to open com port\n" + ex.ToString());
button.ButtonPressed += ButtonPressed;
void ButtonPressed(Button sender, Button.ButtonState state)
if (comPort.IsOpen)
button.TurnLEDOn();
try
var buf = Encoding.UTF8.GetBytes(DateTime.Now + "\r\n");
comPort.Write(buf, 0, buf.Length);
Debug.Print(ex.ToString());
button.TurnLEDOff();
Debug.Print("Com port not open");
void ComPortErrorReceived(object sender, SerialErrorReceivedEventArgs e)
string eventTypeName;
switch (e.EventType)
case SerialError.Frame: eventTypeName = "frame"; break;
case SerialError.Overrun: eventTypeName = "overrun"; break;
case SerialError.RXOver: eventTypeName = "RX overflow"; break;
case SerialError.RXParity: eventTypeName = "RX parity error"; break;
case SerialError.TXFull: eventTypeName = "TX buffer full"; break;
default: eventTypeName = e.ToString(); break;
Debug.Print("Error received : " + eventTypeName);
void ComPortDataReceived(object sender, SerialDataReceivedEventArgs e)
case SerialData.Chars: eventTypeName = "characters"; break;
case SerialData.Eof: eventTypeName = "EOF"; break;
int available = comPort.BytesToRead;
Debug.Print("Data received : " + eventTypeName + ", " + available + " bytes");
var buf = new byte[available];
comPort.Read(buf, 0, available);
Debug.Print(new string(Encoding.UTF8.GetChars(buf)));
Some incompatibilities between standard assemblies and gadgeteer ?
