Hi everybody!
I have a minor issue, maybe I am missing something obvious:
I run PWM on 2 ports on the EMX development module(PWM3 and PWM4) and when I run both at the same cycle (1 second) I can vary the speed of both ports without issues - thus 0 up to 100 % cycle, but when I run PWM3 port at 100 ms and PWM4 still at 1 second, the port running the 1 second cycle does not work correctly anymore, 0%, 10% gives nothing and 20% - 100% gives 100% always… (Tested against a 2 second(PWM4) 1 second(PWM3) cycle also - same result)
If I use the ports the other way around then everything seems fine - and in scenario one there are no exceptions(errors) occuring…
Maybe I missed something obvious?
And thanks for an active and great forum!!!
