We have purchased EMX model of GHI. It has come with build in example of USB,SDcard and UART access. Please provide the .netMF C# code for our refernece.
You mean the demo which is already loaded onto the board?
Here it is:
Is it normal that when I use a FEZ Cobra + 7" Display, that I get a OutOfMemmory Exception when I run the demo?
I get the exception every time when I try the SD-Card or the Terminal Demo.
Emx has a lot of memory so you will not run out of memory. There need to be some fixes to code in bitmap alocation. You can rasily fix the code by disposing unused images. This is explained in free ebook. Search for custom heap
