ok, can you do another test? If you have another PC, can you install the SDK again there and see if you can do the full install from there? I had an issue I never tracked down exactly what happened, but refreshing the SDK seemed to make a difference to the installation of the firmware update (I even compared the actual firmware files and they appeared to be consistent, but one would apply one wouldn’t)
I have tried anoter PC with a other download - the same result!
BUT, in a desperate try I did:
Installed TinyBooter with TeraTerm
Startet MSDeploy and installed CLR2.HEX and Config.HEX, only.
Closed MSDelpoy
Started MSDeploy and installed CLR.HEX, only.
Now, came over the crash point in the CLR.HEX
And the EMX did a reboot and it is up running
IT’s ALIVE…
So, the question:
Why did it crash in the first place, on the memory split for doing application updates from sd cards?
I have used this for along time with out any problems… is it a bug in the latest GHI firmware?
I will try all over again… and see if the problem repeats.
