I have several CAN devices which sends 100hz messages each, I need to connect 8 of these modules into an EMX board, when I connect 4-5 of them I am able to receive their messages without any error but when I connect all 8 of them I keep getting RXOver error
How can I avoid this error? I tried to increase the size of the RX messages list without any help, please advise.
Liran
You need to enable filters for the messages you need.
Welcome to the community.
Using code tags will make your post more readable. This can be done in two ways:[ol]
Click the “101010” icon and paste your code between the
tags or...
Select the code within your post and click the "101010" icon.[/ol]
(Generated by QuickReply)
Sorry about the previous reply, hit that button by mistake
- I have only my devices connected, and I want to receive all their messages
- I did setup filter using
SetExplicitFilters(new uint[] { 0x101, 0x102, 0x103, 0x104, 0x105, 0x106, 0x107, 0x108 });
My complete CAN object code is below:
namespace CANTest
public delegate void CANBusDataReceivedREvent(object sender, ref CAN.Message[] msg);
public class CCANBus
private uint m_counter = 0;
private CAN.Message[] m_MsgList;
private CAN.Message[] m_TXMsg;
private CAN m_CAN;
public CANBusDataReceivedREvent DataReceivedEvent = null;
public CCANBus(CAN.Channel Channel, int BRP,int T1,int T2,int MsgCapacity = 100)
m_MsgList = new CAN.Message[MsgCapacity];
for (int Index = 0; Index < m_MsgList.Length; Index++)
m_MsgList[Index] = new CAN.Message();
m_TXMsg = new CAN.Message[1];
m_TXMsg[0] = new CAN.Message();
m_CAN = new CAN(Channel, (uint)(((T2 - 1) << 20) | ((T1 - 1) << 16) | ((BRP - 1) << 0)));
m_CAN.SetExplicitFilters(new uint[] { 0x101, 0x102, 0x103, 0x104, 0x105, 0x106, 0x107, 0x108 });
m_CAN.ErrorReceivedEvent += new CANErrorReceivedEventHandler(HandleErrorReceivedEvent);
m_CAN.DataReceivedEvent += new CANDataReceivedEventHandler(HandleDataReceivedEvent);
~CCANBus()
if (m_CAN != null)
m_CAN.Dispose();
m_CAN = null;
public void SendData(uint ID,byte D0,byte D1,byte D2,byte D3,byte D4,byte D5,byte D6,byte D7)
m_TXMsg[0].ArbID = ID;
m_TXMsg[0].Data[0] = D0;
m_TXMsg[0].Data[1] = D1;
m_TXMsg[0].Data[2] = D2;
m_TXMsg[0].Data[3] = D3;
m_TXMsg[0].Data[4] = D4;
m_TXMsg[0].Data[5] = D5;
m_TXMsg[0].Data[6] = D6;
m_TXMsg[0].Data[7] = D7;
m_TXMsg[0].IsEID = false;
m_TXMsg[0].IsRTR = false;
m_TXMsg[0].DLC = 8;
m_TXMsg[0].TimeStamp = DateTime.Now;
bool SentOk = (m_CAN.PostMessages(m_TXMsg, 0, 1) == 1);
private void HandleDataReceivedEvent(CAN sender, CANDataReceivedEventArgs args)
int NumberOfMsgs = sender.GetMessages(m_MsgList, 0, sender.ReceivedMessagesCount);
m_counter += (uint)NumberOfMsgs;
if (DataReceivedEvent != null)
DataReceivedEvent(this, ref m_MsgList);
private void HandleErrorReceivedEvent(CAN sender, CANErrorReceivedEventArgs args)
//Debug.Print(">>> Error <<<");
switch (args.Error)
case CAN.Error.Overrun:
//Debug.Print("Overrun error. Message lost");
break;
case CAN.Error.RXOver:
//Debug.Print("RXOver error. Internal buffer is full. Message lost");
break;
case CAN.Error.BusOff:
//Debug.Print("BusOff error. Reset CAN controller.");
sender.Reset();
break;
@ Gus - can you please take a look at the code, it includes the setup of filters like you suggested but still no help, I still get the error events
