I was trying to search for solution in the forums, but since the search function isn’t working, I’m posting my issue on a new thread.
So I have a laser with many CAN controllers which transmit ~600 CAN messages per second, if combined. EMX has to catch all that so obviously I need a large buffer. I use 10000:
//Initialize CAN
_can = new CAN(CAN.Channel.Channel_1, (((8 - 1) << 20) | ((15 - 1) << 16) | ((3 - 1) << 0)), 10000);
// create a message list of 10000 messages
_msgList = new CAN.Message[10000];
for (var i = 0; i < _msgList.Length; i++) {
_msgList[i] = new CAN.Message();
// subscribe to events
_can.DataReceivedEvent += CanDataReceivedEventHandler;
_can.ErrorReceivedEvent += CanErrorReceivedEventHandler;
The trick is, when the program runs after reset, DataReceivedEvent is not raised until EMX CAN input buffer is full and ErrorReceivedEvent (with CAN.Error.RXOver) is rased. From the moment ErrorReceivedEvent is raised for the first time, everything works just fine.
That really bugs me, because, during manufacturing, testing, development and debugging, many CAN devices are disconnected and the CAN message flow may be as low as 30 per second; then it takes minutes for the CAN buffer to overflow, and I don’t get any incoming CAN messages until that happens. And people, forced to wait two minutes until the board starts working, wish me a lot of things, that are not exactly… pleasant
The only workaround I discovered is to disconnect CAN cable from EMX while it boots, and reconnect it once the program is up and running. But that’s not really an option, isn’t it?
Sometimes the mode of CAN controller is not in normal mode or listen. So I use a custom made Mode property to be able to set it to either “config, listen or nomal”
public enum Mode
Normal = 0x00,
Sleep = 0x01,
Loopback = 0x02,
Listen = 0x03,
Config = 0x04,
public Mode Mode
get
Register mode;
mode = new Register(CANXMOD + (((uint)_channel) - 1) * 0x4000);
switch (mode.Read())
case 0x10:
return CAN.Mode.Normal;
case 0x01:
return CAN.Mode.Config;
case 0x02:
return CAN.Mode.Listen;
default:
set
Register mode;
switch (value)
case CAN.Mode.Normal:
mode.Write(0x00);
_rsPin.Write(false);
break;
case CAN.Mode.Config:
mode.Write(0x01);
_rsPin.Write(true);
break;
case CAN.Mode.Listen:
mode.Write(0x02);
_rsPin.Write(true);
break;
_rsPin is the slope control of the CAN tranciever and _channel is the GHI CAN channel.
Rearange your code like this could solve your problem.
//Initialize CAN
//the time spend here between init and subsription: if the buffer get's flooded here no datareceived event is raised
