I am working on a system that does some motion control and I want to be able to dynamically load/unload assemblies at run time to control the sequence of motions. The problem is, if I create a new AppDomain to load an assembly and then unload the AppDomain the next time I try and use the same assembly in a new AppDomain the call to CreateInstanceAndUnwrap never returns.
Here is the trace if I step into the call:
Step into: Stepping over non-user code 'System.AppDomain.CurrentDomain.get’
Step into: Stepping over non-user code 'System.AppDomain.CreateInstanceAndUnwrap’
Step into: Stepping over non-user code 'System.Reflection.Assembly.Load’
Step into: Stepping over non-user code 'System.Reflection.Assembly.ParseAssemblyName’
Step into: Stepping over non-user code 'ushort.Parse’
Step into: Stepping over non-user code 'System.Convert.ToUInt16’
Step into: Stepping over non-user code 'System.Convert.ToInt64’
Step into: Stepping over non-user code 'int.Parse’
Step into: Stepping over non-user code 'System.Convert.ToInt32’
I an running with NETMF and Gadgeteer Package 2014 R2 on a Cobra II.
