Driving an S1D13700 4 bit display with the STM32?
Does anyone know if you can drive an S1D13700 Epson based LCD from the SITcore LCD interface? Is this even possible? I have a ton of those displays lying around that I’d like to use. They are visible from a distance.
SITCore has a way to give user raw data bitmap of current screen, user can take data and draw them to any other screen.
I worded it wrong. What I should have said is how to use the LCD interface of the SITcore to control a 4 bit panel in the same manner as the S1D13700 does.
If I use a panel with the S1D13700, it is nothing more than an 8 bit bus with the memory buffer built into the S1D13700 itself.
