So I need help with the following:
I have Fez Flea board and a Mote APA10*16 RGB led bar. I want to drive the led bar using the flea board and I am running it on TinyCLROS using Visual studio 2022.
Hardware connection:
Connected my fez flea board to my pc using a usb c to usb A cable.
Connected the Mote APA led bar to the board using a usb mini connector on the led bar side and soldered wires to the flea board: red to 5V, black to GND, white to pin 10 (PB15 MOSI2), green to pin 8 (PB13 SCK2)
What works:
I can let the onboard LED of the fez flea blink using the following code:
using System.Collections;
using System.Diagnostics;
using System.Text;
using GHIElectronics.TinyCLR.Drivers.BasicGraphics;
using GHIElectronics.TinyCLR.Drivers.Worldsemi.WS2812;
using GHIElectronics.TinyCLR.Drivers.ShijiLighting;
using GHIElectronics.TinyCLR.Drivers.ShijiLighting.APA102C;
using GHIElectronics.TinyCLR.Devices.Spi;
var LED = GpioController.GetDefault().OpenPin(SC13048.GpioPin.PA8);
LED.SetDriveMode(GpioPinDriveMode.Output);
LED.Write(GpioPinValue.High);
Thread.Sleep(100);
LED.Write(GpioPinValue.Low);
Thread.Sleep(100);
When I tried to drive the LED bar using SPI communication, it won`t work, there is simply not sufficient documentation. First of all: is my hardware connection OK? If not, what needs to change?
Second, is my code OK (see below)?
Third is there any in depth guide about how to this? And yes, I already checked the ghi electronics website and tutorials, but is very very short and missing alot of information.
Code that doesn`t work for driving the led bar:
using System.Text;
var cs = GpioController.GetDefault().OpenPin(SC13048.GpioPin.PB15);
var settings = new SpiConnectionSettings()
{ ChipSelectType = SpiChipSelectType.Gpio,
ChipSelectLine = cs,
Mode = SpiMode.Mode1,
ClockFrequency = 4_000_000,
var spiBus = SpiController.FromName(SC13048.SpiBus.Spi2);
var led = new APA102CController(spiBus, 24);
led.SetColor(1, 255, 0, 0); // 2nd LED is Red
Thread.Sleep(100);
led.Flush();
