I’m coming back to my device after some time away on a clean computer. My Domino is set up to debug through COM via an FTDI breakout so I can use the onboard USB.
Now I’m having issues with the drivers. The FTDI drivers installed fine and I can ping/deploy via that over COM3, however the onboard USB drivers come up as CDC VCOM in Device Manager and my Windows 7 refuses to install the drivers for it, despite pointing it at C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\USB Drivers\GHI_NETMF_Interface etc.
I am not sure. Are you debugging over serial (FTDI)?
Then you used our USB client feature to make a CDC? The drivers for CDC have a link under CDC documentation in our library.
