When I run compilation, VS stopped on the message “the debugging target initialized” and nothing happens. For running the program, I need to restart it manually, but debug does not work after reboot.
I use Cerberus board
@ magals
Which hardware are you using?
I have reproduced several times this problem with VS2012, Cerb platform on Windows 8, for me only work fine when switch to old USB Drivers “legacy folder”.
Regards,
PepLluis,
which older usb drivers?
First off check out the troubleshooting guide located at https://www.ghielectronics.com/docs/165/netmf-and-gadgeteer-troubleshooting.
thx. I installed legacy usb drivers. all good
@ magals - Great!
